The freezer portion of my LG refrigerator has stopped getting cold - it is still cool enough so that the meat does not thaw, but ice cream does get very soft. This appears to have just started.
It is likely to be either the circulation fan in the freezer or the defrost element. Check the fan is running( you can usually hear it stopping as you open the door, some still run) otherwise it could be a defrost problem, if the element doesn't work the rear fills up with ice and the air cant flow. Both are behind the rear panel of the freezer.
SOURCE: LG REFRIGERATOR - FREEZER ON BOTTON
You have not only to unplagge the unit, but also to pull out all of frozen, or cold food and other things like baskets etc. and to keep open all dors. All of unit, including inside parts, has to "warm" to home temperature and after that to stay as minimum 24 hours. If you leave frozen food iside unit and closed doors you have to wait a week or more. DON'T USE STEAMER! YOU WILL DAMAGE PLASTICS. DON'T APPROACH FROM BACK SIDE!
SOURCE: Freezer and Refrigerator are not getting cool enough
there is more ice built up behind the panel
defrost is not working
SOURCE: LG refrigerator freezer is not working, its not
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
aeryeqr
SOURCE: Refrigerator section not cooling
Hi, Refrigerator or Freezer not Cooling or Getting Cold
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
SOURCE: My LG refrigerator does not
Hi, If you are hearing a clicking or buzzing then check out the last two tips.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
heatman101
