Question about Casio PCR-T2000 Cash Register
Print receipt casio
Receipt tape is not printing, journal tape is printing. we are using thermal tape. any suggestions?
Posted by afr4 on
Patrick Tinashe Tasiyana
  • Casio Expert
  • 592 Answers
Next to the date/time button , there is a button written receipt/on/off
press that one once...good luck
Posted on Oct 11, 2013
Hi the receipt will not print out but the journal is fine, do you know i can fix it?
Have you checked to see if the paper is in the correct way round, most tills have a receipt turn off mode. Consult your manual to find out how to switch back on
Aug 02, 2014 | Casio Cash Register
Journal tape
What this means is your machine has the Journal-off function activated
Jan 27, 2014 | Casio TE-2400 Cash Register
How do i install ink cartridge in royal alpha 1000ml
There is NO ink in your cash register.
Your cash register has a thermal printer that prints receipts for the
customer or a journal tape. Use 2¼ inch (57.5 mm) wide standard thermal register paper. Do not use bond paper because the register does not use a ribbon or ink for printing.
See installing paper roll on page 13 of the manual
Royal 1000ML Instruction Manual
Nov 24, 2013 | Royal Office Equipment & Supplies
My casio PCR -T2000 won't print receipt paper. The paper is not moving. There is no error on the screen. There is no jam. It is the correct thermal paper. I've tried turning power off and on and...
You haven't mentioned the journal roll, so I will assume it prints the journal but not the receipt. What happens if you press the post receipt button at the end of a sale. Does it print daily reports on both rolls? --------------------------------------------------------------------
If anyone needs a Casio PCR-T2000 manual, C-tech collective have it here: http://the-checkout-tech.com/manuals/cashregisters/Casio3.php
Jul 25, 2011 | Casio Parts Cash Register PC Desktop
Receipt won't print after paper change (and it IS thermal...)
not knowing what the model is I suspect the machine suffered a power surge or got a spill
Aug 26, 2009 | Casio Parts Cash Register PC Desktop
Paper
Hi. The PCR-T470 is only a single roll machine, so if you had them printing at the same time, you would be handing the customer your journal when you gave them their receipt. This machine can be setup either as journal only (in which case you use the black takeup reel that sits inside the printer housing), or receipt mode (in which case you have the paper coming out of the front of the printer cover). The best thing about single roll machines is that when you have them in recipt mode (recommended), you can print the journal out of memory whenever you want. to do this, turn the key to X mode and press RC button until you see 'electronic journal', then press CASH to print it. you might be able to reset the journal by doing the procedure in Z mode (the manual isn't clear about this). Give it a try.
Hope this helps. Let me know if you have more trouble.
Mark
Sep 04, 2008 | Casio Parts Cash Register PC Desktop
Journal receipt won't print.
Hi. The journal side should always print (right side of printer). There is no way to turn it off. If it is feeding the journal paper, but not printing, then you may have the roll in back to front (in the case of thermal printers). If it doesn't feed at all, then you may have a feed problem. In this case it will usually be printing over the same place on the roll continuously. Another thing to test is whether it prints on both rolls when printing Z reports.
If none of this helps, then please let me know the brand and model number, and I will try to suggest more checks.
Mark
Aug 30, 2008 | Casio Parts Cash Register PC Desktop
Casio PCR-T2000 Cash Register Logo
441 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
Marvin
Marvin
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
