Question about Freezers
Temprature blinking Temprature on my samsung side by side fridge/freezer model RSA1WTMH blinking and freezer not freezing
Posted by Frederick Yeboah on
aprilkay0981
    New Friend:
  • 11 Answers
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Posted on Jul 24, 2013
5 Related Answers
Anonymous
  • 13 Answers
SOURCE: Whirlpool FRS Side by Side Fridge Freezer
Hi Simon I saw that problem because you have a hole in the bottom of the freezer connecting directly on the wall of the fridge you need to block it ... because the air flow directly from the freezer 2 the fridge . Hope it was helpful.
Francois
Posted on Jan 21, 2009
Dickson LAU
  • 86 Answers
SOURCE: Intermittent freezing and fridge warm
The ice builds up in the freezer compartment because the defrost cycle is not working. Check the timer , the defrost elements the defrost thermodise.
God Bless.
Posted on Jul 07, 2009
John Broderick
  • 82 Answers
SOURCE: whirlpool fridge freezer alarm s20D RSB33AG-B
Hi, you have a common problem with your control boards; there is a cheap fix if you can use a soldering iron or you can have your modules repaired.
Let me know
bb
Posted on Sep 26, 2009
Anonymous
SOURCE: Samsung fridge/freezer model SRS73DTA doesnt freeze.
Hi I have the same problem,
did you get an answer to your question..?
Posted on Feb 02, 2010
Freezer not freezing
What is the model number of the unit?
Nov 05, 2012 | Freezers
Samsung RSA1WTMH i just blew my fusebox and my fridge freezer just flashing 1 led light
hope the following helps you, I had a similar problem with my RSH1 and it took me a few hours searching online before I found the following.
"Hi, I have it on good authority that this is the system check for Samsungs (RS21, SRS20, etc) during normal operation, is to hold the top two buttons down, just until display flashes - this will reset the electronics.
Secondly, if the top two buttons are held down for longer (8 seconds) the display goes blank and will show any error messages in the form of DASHES
I have experimented with unplugging air or frost probes - and the error code you get -on a blank screen is different parts of the last digit lighting up.
Example: when i disconnect the fridge air-probe, shut both doors, hold down top buttons around display - The SIDE of the last "8" digit lights up ! ...strange but true.
But, I need to know what it means when the BOTTOM of the "8" digit lights up"
I am still trying to find a list of the error codes the lines refer to but so far my unit is working fine.
Angus
Sep 21, 2010 | Freezers
There is a switch on the bottom under the door by the floor vent thing, and a light on both sides of it, what does this switch do?
That switch allows a temprature alarm to work or not to work depending on which way it is switched. That way you have time to move your contents when the temprature gets above freezing in the freezer. Please make coment and rate me and my knowledge if this answers your question. Thanks
Sep 05, 2010 | Kenmore 17.1 cu. ft. / 484 liter Upright...
What do the three buttons mean at the top of our neff freezer
First, I'm not a Neff representative.
* Check your warranty. Call for support.https://www.neff-home.com/uk/service/support
* Website; https://www.neff-home.com/uk/products/fridges-freezers/fridges
* Manual (official - requires you to register.); https://www.neff-home.com/ie/service/manual
*** The following is for information only.***
* Model needed for specific solution.
* The buttons are for setting the coldness (harder?)
* There are some models that can change the chill "box" section to a freezer.
* Product specs (Official); https://www.neff-home.com/uk/products/fridges-freezers
* Neff Integrated Fridge Freezer K8524X8GB Product Overview (check 0:35) ; https://www.youtube.com/watch?v=NVqMz7cbY4o
* Neff K5920L0GB Side By Side American Fridge Freezer; https://www.youtube.com/watch?v=92ugO2ArjaA
* Neff KA3902B20G Side-by-side fridge-freezer; https://www.ruislipappliances.com/images/PDF/KA3902B20G.pdf
* Catalogs; http://pdf.archiexpo.com/pdf/neff-9796.html
* Products; http://www.jamesratfordbridge.co.uk/downloads/Neff_brochure.pdf
* NEFF KI2823F30G Built In Fridge;http://www.creativelivingni.co.uk/neff9.pdf
* use the posted contacts for specific support.
Aloha, ukeboy57
Jun 06, 2010 | Neff 3.80 cu. ft. / 108 liter Upright...
Whirlpool fridge freezer alarm s20D RSB33AG-B
Let me know
bb
Aug 31, 2009 | Whirlpool Freezers
Jan 19, 2009 | Freezers
Malfunctioning American Fridge Freezer
Is it freezing. Sometimes those led's go out.
Dec 21, 2007 | Freezers
Freezers Logo
308 people viewed this question
Top Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
