Also, from time to time I'm also having issue with PresentationFontCache.exe taking up over 50% of the CPU. I set Presentationfontcach.exe to Manual and re-booted computer, then place Presentationfontcache back to Automatic. I can not seem to get the wmpnetwk.exe STOP taking over the physical memory and at that point, accessing any programming on the computer is NOT Responding. Any advise..
SOURCE: automatic windows updates
r u wnt to stop your automatic update...........go to control panel then setup windows firewall or security center open left side change the way security center alerts me . all ok mark disable ..then apply ok
SOURCE: Microsoft server 2003 enterprise edition
This is a problem in RAM , replace one by one if you have more then one module of RAM.
The problem will be solved
SOURCE: Virus Side Effects; Safe Boot; Drive Access denied
try to restore your system ;
start, all program, accessories, system tools, system restore and try to restore an earlier point which you will choose
SOURCE: Help needed !!!
Wmpnetwk.exe is a media player network sharing service. It is annoying and useless(as you have already noticed).
Click start->Run->Type in "services.msc"(without the quotes). Then click on the services tab, and uncheck the box next to wmpnetwk.exe. Click apply, close the configuration utility and reboot your computer. If you ever want to start the media sharing service again you can start it from windows media player.
Hope this helps,
Sai.
Testimonial: "All your help was fantastic. I'll be recommending you to friends that's for sure !!"
SOURCE: is 67 processes normal in task manager?? and is 5 chrome exe in tm using 170000k normal too???
If the processes are from all users it is.Yes chrome using this sum of memory is normal.
This package contains DCP v1.6 for MC9090c50 devices.
DescriptionGeneral Issues Resolved
Fixed memory leak problem in notify API
Set default date after cold
boot - 1/1/2007
Fixed issue in web browser
wherein the control which had focus prior to the browser's minimization
lost the same when the browser was restored
Fixed SDMMC driver
for potential SD card corruption
Added support for Simple Network Time Protocol (SNTP)
Fix for 'Adapter not available'
error
MC9090 specific changes
Support for new display panel on all 909x color configs.
Support for USB mouse
IDOCKIT v4.01.01.0 cab file included in application partition.
Fix for a silent .wav file producing a high pitched sound.
Wavelink TE 6.0.42.
Implemented the
IOCTL_HAL_GET_UUID.
Fix for download in Bgz format and download via SDcard
1.
9090c50BenDC010604.exe
Microsoft Windows 2000 or Windows XP Operating System
Download the 9090c50BenDC010604.exe file.
Double click the file.
Follow the install screen prompts.
9090c50BenDC010604
July 25,
2007
All the best,
Ben
