Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
I have a Frigidaire model FRT21LRG
Copressor is hot freezer not working runs all the time. Help!
Posted by El Chicote on
Anonymous
    New Friend:
I have a Frigidaire Refrig that the freezer is not freezing like it should. Water is dripping out the sides of the edge of the refrig. What do you think is wrong?
Posted on Feb 12, 2010
Ronald Rousseau
  • 63 Answers
CHECK TO SEE IF THE CONDENSOR FAN IS WORKING IT COOLS THE COMPRESSOR IF IT IS THEN UNPLUG IT AND LAT COOL DOWN FOR A DAY THEN TRY TO SEE IF IT WORKS BETTER IT MAY NEED A RELAY OVERLOAD TOO BUY A 3 N 1 START KIT IT TELLS YOU HOW TO WIRE IT ON THE PACKAGE
Posted on Aug 30, 2007
My upright freezer runs more than it is off
general design requires compressor on off ratio to be total run time to be 18 hrs on per 24 hr day off time allows compressor to cool down averaged over the day cool air is required around the outer walls of the fridge to cool the condenser coil at the rear also
Oct 03, 2017 | Frigidaire Freezer Refrigeration White...
I have a Frigidiare FRT21LRG refrigerator about 10 years old. It is working fine but the kitchen floor in our rental house is unlevel. The refrigerator sits about 1 inch lower on the left than the right...
Some refrig's will have leveling legs built into the bottom that you can adjust with a screw driver.
If the unit does not have them, you can receive the ones for your model at this website:
http://www.repairclinic.com/Appliance-Parts?s=t-5303212922-%3d%3d
Sorry I did not have the units myself or I would have directed you to my sight for purchase:
http://stores.ebay.com/Discount-Appliance-Parts
Sep 15, 2010 | Frigidaire Refrigerators
Describe your FFU2124DW12 Problem The freezer works very good and gets very cold, But the outside walls and top gets EXTREMLY hot
Freezers have tubes that run inside the walls and top of the case, these carry the refrigerant thru the heat exchange process, this will cause the outsides and top of the freezer case to get warm/hot some times, this is normal, but I recommend you to make sure there is at least 1 1/2" of ventalation clearance around the entire freezer so that it can exchange heat efficiently.
If you don't think the amount of heat present at the outside of the freezer case is NORMAL, then I recommend contacting Frigidaire directly and discuss this with there customer service people.
1-(800)FRIGIDAIRE
GOOD LUCK !!
Aug 03, 2010 | Frigidaire Freezers
Model ufp19n-lx2 freezer will freezebut motor run all time and hot
its very likley that the thermostat has stoped working in the on posion and the freezer is running 24/7 this wont do the compressor any good at all, change the thermostat asap,
Nov 22, 2009 | Frigidaire Freezers
Food in freezer not frozen; food in refrigerator not cold
1.check the coils on the back or under side.
2.check if compressor is running
3.check if copressor is hot
4.let me know the answers
Jan 14, 2009 | Freezers
Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Dan Webster
Dan Webster
john h
jdthefixer
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
