Question about Electrolux Vacuums
Hi- Anyone have a manual for an Electrolux 1205 they could photocopy or sell? Thanks- Mary
  • mary14889 May 08, 2009
    Hi, thank you for the two posts. Jmmailin recognized that the 1205 is a ligiitimate, pre-Z model number. Unfortunately, I didn't get the offer of the manual in time to try to change the belt myself and we hired a repairman to do it. It did indeed need a new belt but unfortunately has more serious motor problems as well. So, yes, I would be pleased to receive the manual to see if it can help us with this fine old vacuum cleaner. Please send it to [email protected]. Thank you!
    Mary
  • Ryan S
    Ryan S May 11, 2010
    Hi Mary
    Does the model number start with any letters? You'll find the proper model number under the serial badge on the machine. Usually Electrolux models start with a Z. Please update the necessary info on this post.
Mary - Electrolux just sent me a photocopy of the manual for the 1205. It's not a very good copy but it's mostly legible. I've just scanned it to PDF and would be glad to send by email. [email protected]
Posted on May 07, 2009
  • michelle gyorgy Oct 05, 2013
    jmmailin, could you send me a pdf copy if you still have it? Just got the parts the fix a the wheel and the handle on mine. Wheel was no problem. Handle, I took 3 screws out, then the facing (for lack of a better word) came off, but then more screws. Even taking the other 2 out, I couldn't figure out how to get the broken handle off.
6ya staff
SOURCE:
Repair manual for an electrolux 1205
That job should be handled by an authorized repair service. Please do not attempt this on your own.
Sep 18, 2016 | Electrolux Vacuums
How can I replace the rechargeable battery?
Hi There,
Officially Electrolux don't want to sell the batteries so they discount the price of the hand held unit. Here in Australia they are called ergo rapido but it will be the smae everywhere I would assume. They will sell the battery on its own but it is more expensive than replacing the hand held part (without the filters) .
Jun 12, 2012 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
I need part a break down for electrolux model 1205 vacuum cleaner with factory part numbers, I would like it to have the motor and fan parts break down and numbers to be able to replace the fan blades, I...
The motor and fans are a single unit/assembly. Schematics and parts lists are only available to authorized service techs and franchise owners.
The company that made this machine is now Aerus. You can purchase the correct parts through your local Aerus Electrolux dealer. They know the parts to order for this machine and will provide the correct ones.
http://www.aerushome.com/storelocator/
Apr 07, 2011 | Vacuums
We bought a new cord winder for our Electrolux 1205 Canister Vacuum cleaner and we are trying to install it is not turning on. We get it all connected but it doesn't turn on. Is there a reset button or...
Did you put a bag in the vacuum?
I suspect there's an improper wire connection somewhere, but there are other things that could cause this I strongly recommend taking it to an authorized Aerus Electrolux dealer and letting a trained tech check it out.
Mar 21, 2011 | Electrolux Vacuums
I need a user manual for the VCU007 upright vacuum
Hi, i have a user guide which i am happy to photocopy for you and post...would this help ?
Apr 06, 2010 | Vacuums
Do you know of anywhere I can get an electrolux repair manual for the 1205 model - I need to replace a motor. I have the motor Arthur Gaucher
Electrolux does not make their service manuals available to the general public or non-Electrolux service personnel.<br /> It
Feb 24, 2010 | Electrolux Vacuums
I was given an Electrolux vacuum model 1401-B. I would like to download a manual for it. Do you have one? Thanks, Carolyn
Carolyn, The 1401B is one of a family of US built LUX models , now sold by AERUS Electrolux. It shares common info with the MARQUISE, Super J , Olympia and 1205, etc so if you come across a used manual for any of them you will be in good shape.
Try an AERUS Electrolux dealer but the manual may be out of print.Also try a local vac shop
Quick rundown, :
Set the dial at front between medium and fine and don`t adjust, this is the bag fill control, NOT a suction control.
Only use genuine 4 ply filter bags from a pro vac shop, not grocery store grade as this is a vac which filters thru its bag.
Hang the hose for longer life, obstructions can be blown out thru plugging the hose in the blower port under the slide door behind the handle.
Inspect the power head for hair and thread and remove any visible.
When you wheels squeak while vacuming spray the axle shaft behind the neck with a drop of WD 40.
If you feel air venting thru the hose behind the handle or if it is crushed and kinked there or at the vac replace the hose for better suction. The weight of this vac weras out hoses. When the castor below the body cracks and it will, match it with a small SHEPARD castre at the hardware store.
If your rewind is sluggish, pour a tablespoon of talc or baby powder in a tissue and run it up and down the lenght of the vac cord end to end. Then drop the tissue into the vac bag fro fresh scent.....
Enjoy the vac, this one is a great one 30 year plus life span, parts are still available keep it in good repair
Oct 10, 2009 | Vacuums
User Manual for Electrolux Model 1522 Double Insulated Floor Shampooer
I just bought the Electrolux Floor Pro Encore at a yard sale and need the manual. The URL above isn't working for me. What am I doing wrong.
Mar 23, 2008 | Vacuums
Vacuums Logo
642 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
MarkSA
Level 1 Expert
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
