:\windows\system32\winload.exe " Status: 0xc000000f This error message states a missing or corrupt Winload.exe file, due to which the booting process of the system halts and the data stored in the hard drive becomes inaccessible.
Cause: Following are the causes for the corruption in Winload.exe: Software or hardware issues. Corrupt Boot Configuration Data (BCD). Incompatible partition.
Resolution: To resolve the above issue, consider the measures below: To fix the corrupted Winload.exe file, use the Windows Recovery Environment. To do so, use the Startup Repair option in the System Recovery Options dialogue box and choose the operating system to repair. Using the Windows Recovery Environment will restore the system to a particular point, which will get the system to an appropriate working state. In most cases, the above measures will help you to resolve the issues related to Winload.exe. But, if the problem persists, then you will need re-install Windows. But, a clean re-install of the Windows operating system deletes all the data stored. In these situations, to recover your data completely, it isrecommended to use a high quality
Windows Data Recovery Software. The
Windows Data Recovery application incorporate advanced scanning algorithms to ensure quick and comprehensive recovery of your data. Stellar Phoenix Windows Data Recovery v4.1 is the most appropriate utility that recovers your lost, deleted or inaccessible data accurately. The Windows Data Recoveryapplication offers highly intuitive graphical user interface, that makes it easy to use and understand without any prior technical understanding. This recovery tool is fully competent to recover data from FAT16, FAT32, VFAT, NTFS and NTFS5 file system based disks. The read-only software is compatible with Windows 7 RCI, Vista, XP, 2003 and 2000.
