Car Shakes every time I drive over 40 MPH my car starts to shake and when I hit he brakes the car pulls to the left and the steering wheel vibrates. I had my brakes changed recently and had a wheel alignment but the problem still persists and is getting worse.
Certainly sounds like a partially, or seized caliper hanging up, which has warped rotor. What exactly did they replace at brake job, do you know? Either way they need to be rechecked.
When you hit the brakes, or just driving down the road ? Most wheel balancing machines only duplicate road speeds of 40 mph. So it could be a tire or wheel.
Could be a wheel, tire, or axle shaft. You could rotate the tires front to back and see if the vibration moves. If it does the problem is one of the tires or wheels. If it stays in the front, its probably one of the axle shafts. It could also be a hub bearing or something loose in the suspension. But a loose suspension part would normally show up when you hit a bump rather than on a smooth road.
Vibration from about 40-60 mph is usually attributed to wheel balancing, but the onset when you hit a bump seems to indicate play in the steering linkages (tie rods etc) or suspension members and stabiliser bar rubbers but you had that all checked out, that brings us back to the wheel balancing.
If the steering wheel starts to shake between 55-65 MPH then you need to balance the wheels. If it shakes when you press the brakes, your brake rotors are warped and need to be cut or replaced. If the steering wheel shakes at low speeds then it's possible one of your rims is bent or one of your tires is out of round. Leaving a car parked for a long time in snowy and icy roads will damage your tires, causing them to warp. Depending on which situation is causing your steering wheel to shake, have it looked at.
OK, when the ABS module is unplugged, the same results. That tells me that the ABS system is not working properly.
Did they look into the master cylinder and other abs related components?
Any ABS codes on it?
If steering wheel shakes above 50 mph that's likely to be the tires on it, rather than a brake problem.
Have tires balanced and rotated and inspected for out of roundness that might cause vibration above 50 mph.
