The monitor get on for a second, then it goes black
I can only get a picture on my monitor fro only a second before it goes black. I have tryed to restart the monitor and the computer. No result. It seem to be a problem with the monitor.
The picture board on your monitor is bad, since it goes
off after few seconds and the power led or button is on, it means the
board of your monitor has developed fault.
The best thing for you
to
do now is to take the monitor to a local repairer or service center
within your vicinity
to help with the replacement of the picture board
because the fault is not something you can fix yourself, in order not to
complicate issues.
to
do now is to take the monitor to a local repairer within your vicinity
complicate issues.
I believe the power led button is still on while the screen goes black, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes black after that
Since the power led button is on, It means the picture
board on your monitor is faulty that is why it appears for a second and goes black.
The best thing for you to do now is to take the monitor to
a local repairer or any service center within your vicinity to help
with the replacement of the picture board because the fault is not
something you can fix yourself in other to complicate issues.
black after three seconds, it means the
to
do now is to take the monitor to a local repairer within your vicinity or any service center
complicate issues.
Try the monitor on another computer that you know works, If it works on another computer then that means you have no video output on the original computer and you'll need to reseat the memory on that computer.
If you get the same response on another computer, then that means the monitor is bad and you'll need to replace it.
did you adjust the brightness, also in windows settings?
pls check with another monitor ,also you can check monitor with another pc or laptop
try with reset the monitor settings
also change the resolution and display frequency
Video (picture) must be constantly entering a monitor for a monitor to continue to display a picture after it self tests (goes on for a second or, two) Your monitor is fine; check it using another known good computer.
Try shining a flashlight on the screen, or without the flashlight, try to see if you can distinguish anything on the screen at all, if you do, the backlight is dead, or the monitor has an internal most likely unfixable problem.
plug in a different monitor temporarily, check your display settings (right click background, settings, advanced, monitor)
and set refresh rate to 60hz.
plug in this monitor again and see if that helps
some monitors (lcd's especially) cannot handle beyond 60hz
Is it going back and forth? Image...Black...Image..Black?
