SOURCE: my a/c is leaking water out of the pan the back
TAke your drain line loose at the coil.And blow thru it with air or turn the shop vac arond and use it to blow it out. The best way and I use this is a shop vac at end of the line if you can find it.
SOURCE: When the unit stops running water is leaking down
Either the drain tube is blocked or the drain tray has a hole rusted in it. My unit is a York and I replaced the condensate drain tray.
SOURCE: Leak is around inducer housing where i can't see.
Leaking water? Check the condensate hose for a blockage. If the condensate hose is missing, put a hose going to the sump. Make a small loop in the hose lower than the blower housing to add restriction of the blower so the pressure switch closes.
SOURCE: drip pan wet furnace filter lennox air handler
verymuch so it is clogged up , now open system treat drain pan with bleach ,blow out two lines if there are available but if theres only one treat that on ,then treat the coils clean an treat them after cleaning pour little bleach in the bottom of the pan
SOURCE: leak in ceiling under a/c
There should be a plastic PVC fitting exiting the home maybe high above a exterior window. Find that line and then use a wet/dry vacuum to remove the blockage. If this doesnt seem to do it, you will neede to open the panel in the attic to access the other end.
