Question about Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
I have a 2 drawer dishwasher that has started showing the F1 code in the display window of the upper and lower sections of this dishwasher. What does the F1 code with a wrench flashing in the bottom left of the screen mean?
thanks
jj
Turn off dishwasher's circt braker at distribution panel (usaly located in garage or in basement)
1. Open lower drawer
2. Push in two plastic buttons at front lower corners.
3. Remove drawer from railing
4. Remove water from bottom of dishwasher
5. Use hair drier to dry off bottom copartment, specialy in left corner at floding switch location.
6. Install drawer on the rail in position when plastic buttons pup up
Posted on Apr 21, 2009
Also you want to go to diagnostic mode select LD lid down. make sure both actuator are working, meaning both are pulling down the lid. mine what happen is left side actuator motor is not working any more. so when I start unit right actuator motor pull the right side of the lid but the other side since motor not working leave that side open. when spray arm spray water. water coming out and flooding bottom panel. later unit will raise fail code F1.pump motor will start running like forever.
Posted on Apr 22, 2009
Should I call a technician or is it something anyone can fix?
