Okay, this feels stupid, but here goes. my contractor finished & left a dusty mess. He let me borrow his shop vac, which I've never used, but left it unhooked. I can't get the hose to connect to the vac. Can't find instructions online either. Please help.
clueless homeowner
SOURCE: after i cleaned the filter, shop vac doesn't turn back on
IT SOUND LIKE THE MOTOR WENT BAD OR IN SIDE THE PANLE A WIRE CAME LOSE
SOURCE: Shop Vac 12 wet dry canister
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19255&thid=245090
Posted by Fa Fa on Nov 05, 2007
I'm not certain I have all the parts to my Shop Vac. I have no instructions so I need help describing how it works and a picture of the main parts.
Thanks for any help. Julia Harris
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I am supplying you with the contact for the Shop Vac Factory Service for owner’s manuals listed below: for the website and the customer service line, but make sure you include the Shop Vac Model # and the Serial # as well. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://shopvac.com/contact.asp Customer Service 570-326-0502 Phone #
Shop-Vac Corporation Customer Service 570-326-7185 Fax #
2323 Reach Road
P.O. Box 3307
Williamsport, PA 17701
Hours are: Monday thru Friday 8:00 am to 5:00 pm (EST)
SOURCE: Shop Vac
You **** up water the same way as dirt. It's designed this way, hence the name wet/dry. Just be sure not to get the water in the very top of the unit where the motor sucks the air for cooling ventilation, if water gets in there it can burn up the motor. A little hard way, personal experience, speaking there.
SOURCE: Bought house. Inherited shop/vac. A bit old, but
If you are going to use the wet vac to remove water, be sure to remove the bag inside the canister first. Also, some wet vacs have an internal float that has to be installed, but that may not be the case with yours.
SOURCE: vacuuming up water with Shop Vac model 84M200
when picking up dry materials use the foam sleeve that slips on and the blue cloth (assuming there all blue) over it, there should be a ring that slides over blue cloth to hold it in place over the foam sleeve, for wet pick up u can use the foam sleeve minus the blue cloth but let it dry out before picking up dry stuff, you can pick up both wet and dry with a cartrige filter that looks simular to a car air filter and it slips over the foam sleeve, but let it dry out after picking up water before picking up dry cause itll just clog it up
