The disc opens up the first 3 menu choices, but when i tap on the 4th menu it reads disc error and will not open.Any help i would appreciate. Thsnk you.
Sounds like a bad disk or the floppy drive is going out. The floppy drive is very expensive to replace. It may be that a local dealer has a used floppy drive which they will install at 1/2 price. If you determine that the floppy drive is at fault, take it to authorized Husqvarna Viking dealer for repair. This is not something that can be done by the owner. Check Husqvarna Viking website for dealer closest too you. If you are the original owner and you purchased it less than 5 years ago, the drive may be under warranty and you would only pay for the labor.
solution entered
sounds like a bad disk or the floppy drive is going out. The floppy drive is very expensive to replace. It may be that a local dealer has a used floppy drive which they will install at 1/2 price. If you determine that the floppy drive is at fault, take it to authorized Husqvarna Viking dealer for repair. This is not something that can be done by the owner. Check Husqvarna Viking website for dealer closest too you. If you are the original owner and you purchased it less than 5 years ago, the drive may be under warranty and you would only pay for the labor.
