LeapFrog Scout My Puppy Pal Logo
Anonymous Posted on Jul 07, 2013
SOUND I JUST REPLACED THE BATTERIES IN OUR SCOUT AND HE NO LONGER MAKES SOUND, HIS HEART LIGHTS UP, BUT NO NOISE.
Need help, what can be wrong at this point. Have tried several test and replaced the color wheel, but nothing was or is making any noise ??
I think you have lost the fan. Check the installation and make sure the fan switch is activated. You must have a fan going or the bulb will actually burnout soon that is why the fail safe circits are shutting it down; to keep the lamp from burning up. Got to get the fan going.
Sound system makes a thump thump noise
Your speaker is now blown.. Replace the Speaker and you will get sound back instantly. Happened to my Drivers Speaker last week, replaced the speaker and life is good again.
1helpful
1helpful
I have turned my sound off on my watch and the alarm sound but when I am working out my watch beeps at every heart rate, its annoying I know there is a way to have no sound, I had it that way before but...
Assuming that your limits are set correctly, this is a job for a Polar Authorized service center.
There is most likely a problem with the computer, depending on the age of the watch this will be taken care of under warranty. The link above explains the process.
If you replaced the battery yourself (never recommended) some contaminant could have gotten into the electronics, or the seal is no longer working allowing moisture into the unit. These are highly sensitive electronics and should only be handled through the service centers. The work they do is covered with a warranty and they replace seals and vaccuum pressure the watch to make water tight again, as well as run a diagnostic on the computer.
In the mean time if you don't want to send in you can set the Heart Rate limits - both low and high well above your actual limits and that will stop the beeping, as the beeping while you are working out is an out of limit/ zone alarm.
Big screen no picture and makes heart beat noise?
can be a faulty mains board, does the sound still work? if not, can be mains board, and at last if there is a continuous clicking sound it a faulty power supply.
hope that help
pls rate me!
Top LeapFrog Toys Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
