Question about Staples SPL-P500 Printing Calculator
What do i do?
When my calculator is on "print" mode, it says "error" in the top left corner, and wont let me type in any numbers or print anything. I tried to press the reset button, but all it did was nothing. While I was pressing the button the screen went blank but after I released the button, it went back to what it said before, and nothing changed. I also lost my instruction guide, please help! Thanks!
Posted by Catherine on
1 Related Answer
Anonymous
SOURCE: I'm using a Staples scientific calculator BD-6108
What is BIN at the top of the screen? How do you get rid of it?
Posted on Jan 26, 2011
I will be adding up multiple things, it is printing great, and then the screen goes blank except for a small "e" appears in the lower left hand corner and I have to start all over. WHY?
our calculator is beyond repair. You can use it in no print mode ohly. The printer is not working, causing the error code.
Turn it off and back on and only use the display mode.
Oct 22, 2015 | Canon P23-DH III 12 Digit Printing...
My Casio fx-9750GII wont dispay a table
The message dimension error usually refers to instances where two lists do not have the same dimensions (number of elements)
I checked and the calculator gives condition error. Check the type of function you are creating a table for. Choose the type y=
Nov 05, 2012 | Casio Calculator Graphing FX 9750GII...
Are there spare part type belts for Sharp printing calculators?
Please contact your local Sharp service. Usually professionals have more extensive access to Sharp spare part databases.
Regards,
Juha-Matti Vihtanen
Oct 09, 2012 | Sharp Office Equipment & Supplies
How do I type an equal sign into the calculator? As in 5x+6=6x-3. I want to put this equation into the calculator, but i cannot figure out how to type and equal sign
Look at the top left corner of the keypad. If you have a = sign marked on the f ace of the calculator (near a CALc or Solve key) you can enter the = by pressing [ALPHA] then the key next to which there is an = sign.
If you do not have that second = sign, you cannot enter it.
The FX-115ES and the FX-991ES do have that sign to allow the user to enter equations. In your calculator you only have three calculational modes: the general COMP mode, the STAT mode and the Table Mode. No equation mode. Sorry.
Aug 30, 2011 | Casio fx-300ES Calculator
I need the answer to this 5^-3 it equals 1/125 which key do I press now to convert the answer? Thank you
Press the"SHIFT" button in the top left corner, then the "MODE" button on the top right.
Select 2: Line10
This will always give you a decimal answer. When you want to switch back to fraction, just select number 1:Mth10
Jun 28, 2011 | Casio FX-115ES Scientific Calculator
I have codes I cannot clear.
It may help to have the Brand and model of the calculator. But I suspect you pressed a Mode button, which gives you different configurations (modes of operations) for the calculator. If I guessed right you will have to enter a number between 0 and 3. If mode is not what you want, try a new number each time.
Hope it helps.
Sep 10, 2009 | Office Equipment & Supplies
Canon P170-DH
for calandar
turn on.
press clock calandar button, top row second from left.
press time set button, second row from left, 3rd button from top, (has time set printed diretly above)
enter numbers, say 03 05 2009
press time set button 3 seconds
press CE/E, red key at bottom left corner.
turn on
press clock calandar button once, date will show
press clock calandar button 2nd time, clock will show
press time set once
enter time
press am/pm button (below time set)
press time set for 3 seconds
press CE/E red button to return to calculation mode
thats it
Jan 10, 2009 | Canon P170-DH Calculator
Wont stay on.
try changing the watch-battery as well
Nov 04, 2008 | Texas Instruments TI-84 Plus Calculator
Cant get the % key turned off.
HI..if this is a printing calculator and the print mode is turned...if there is a problem with the printer and E for Error will appear. The ribbon or some paper could be jammed in the printer..a key could be stuck down..check your entire keyboard key for sticking.
The calculator wont hurt itself and that is why the E is on. Examine it very carefully and look for something caught in it.
If none of the above you might have to get a pro to look at it.
Hope this helps you out....
Squipps
Jan 29, 2008 | Casio HR-100TEPlus Calculator
Staples SPL-P500 Printing Calculator Logo
82 people viewed this question
Top Staples Office Equipment & Supplies Experts
John mullen
gbob59
Marvin
Marvin
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
