Question about Lowrance Boating
I need operator's manuels for 2006 X17 (GPS unit?
I need operator's manuels for 2006 Lowrance X17 (GPS unit).
Posted by alhughes4 on
Anonymous
    Problem Solver:
  • 10 Answers
Http://www.lowrance.com/en/Downloads/Manuals/
Follow this link, then scroll down to your selection. It will download as an Adobe file.
Triton72
Posted on Mar 27, 2009
My new Lowrance Hook-5 GPS isn't working, I'm a noob, how do I get this function working?
'isn't working' is such a broad problem. If it is only the GPS, it is covered from Page 49 of the manual and shows you can access Satellite information. Note, it almost certainly won't work in your garage or storage. It need to see the sky as the antennae is internal.
The unit has an installation guide. In my personal opinion, it is better to let a professional boat engineer install it, mainly for the correct fitting of the transducer on the stern. Correct placing makes all the difference to a good set up, unless you intend to fish without the engine running.
All they need is mounting, power through a fuse direct to the battery, and the transducer fitting. Then you put the boat in the water and switch it on.
Installation Guide
http://www.lowrance.com/Root/Operator%20Manual/Lowrance/HOOK-5-SERIES_IG-MT_988-11024-001_w.pdf
Manual
https://www.lowrance.com/Root/Operator%20Manual/Lowrance/HOOK-SERIES_OM_EN_988-11004-002_w.pdf
Full Specs
HOOK 5 Fishfinder and Chartplotter
Apr 24, 2017 | Lowrance GPS
LOWRANCE HDS7 WHEN I TURN ON THE UNIT THE LOWRANCE "SEIZE THE DAY"
I can help with geofenced lowrance chartplotters and remove unlock and add language pack. Only gen3 and carbon
skype : denisthegreatest
telegram: @denveronly
Oct 01, 2012 | Lowrance HDS-8 GPS Receiver
When my iWAY 500c gets warm the touch screen will
I HAD THE SAME PROBLEM AFTER I DOWNLOADED THE LATEST UPDATE. I RELOADED IT AND NOW IT SEEMS TO WORK OK. GO TO THE LOWRANCE WEB SITE AND THEN TO DOWNLOADS. LOOK FOR THE UPDATE FOR YOUR GPS AND FOLLOW THE INSTRUCTIONS.
GOODLUCK
Jan 27, 2010 | Lowrance Iway 500c GPS Receiver
Just bought at auction. No manuel.
My apologies. I see now that you have an iWay 250C. Here is the manual as found on the Lowrance website.
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/iWAY250c-manual_0160-201_080706.pdf
Aug 06, 2009 | Lowrance iWAY 250C GPS Receiver
Lowrance LMS 337
I wonder if the module has failed again, have you tried reseting the device?
I'm looking into this but I suspect that repairs are required again.
Jul 09, 2008 | Lowrance LMS-337CDF GPS Receiver
Lowrance332
had same problem with lms337. i had upgraded the unit but had not upgraded the lms2000 gps module. i was turning the isolator on in the boat which powers up gps module, if the lms337 is not powered up as well the gps unit goes to sleep. the upgrade fixes it by checking that the unit has not been turned on periodically. otherwise as soon as you power up gps module also turn on lms337. lowrance product support sorted this for me.
Mar 02, 2008 | Lowrance LMS-332C GPS Receiver
Boating Logo
139 people viewed this question
Top Lowrance Boating Experts
Ekse
Mike
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
