Red light blinks six times. When I hit power button green light stays on for a few seconds, turns off the on for a few more. Then goes back to pattern of red light blinking six times.
Posted by Michael Kelley on
bobby caesar
    Champion:
  • 247 Answers
The kill switch is open ensure the lamp cover presses firmly on the kill switch when u close the lamp chamber door the red light will stop blinking and u can now turn the tv on
Posted on Jul 20, 2013
5 Related Answers
Anonymous
  • 59 Answers
SOURCE: PT-60LC13
there are fans inside tv need to make sure they are clean and free of dust
Posted on Feb 05, 2008
Anonymous
  • 638 Answers
SOURCE: my KDF-55WF655 power led blinking red six times.
oh ho try a hard reset mostly u will solve.
Posted on Jun 13, 2008
Anonymous
  • 848 Answers
SOURCE: red light blinking on power
this all problem may exist in your tv
1. High voltage problem/ deflection circuit problem.
2. Shorted picture tubes.
3. Problem in the vertical deflection circuit.
4. Problem in the audio ouput circuit.
5. Problem in the convergence circuit.
6. Problem in the power supply regulation.
7. Problem in the portect circuit.
8. The common high voltage arcing that Toshiba sets do at the picture tube.
so for getting pictures gently tap on the side of tv if it works then there may be some loose connection you can fix it by soldering
Posted on Jun 22, 2008
Anonymous
SOURCE: Blinking red standby light flashes
blinkig red stand by stay on when powr button hit
Posted on Feb 01, 2009
Anonymous
  • 201 Answers
SOURCE: FLASHING POWER RED BUTTON 7 TIMES
I believe that is a bad power supply board. You can unplug set ,open the back access panel and look for swollen electrolytic capacitors they will most likely be slightly rounded on top instead of flat top like the others.Not sure if just replacing caps is enough we mainly swap out whole board.Some models' replacement power supply is slightly different from original in that a couple of the plugs are in different spots and require an extension cable.
the tv dude
Posted on Jun 06, 2009
My lg plasma tv when we turn it on blinks green 2 times then goes back to red
check for shorted components on YSus board and Y Driver boards (the boards on the left with the back off) This job is for a tech type person.
May 16, 2014 | LG 42PC3D 42 in. Plasma Television
My KDF-55WF655 power led blinking red six times.
It looks like your power module is on the blink. Do you get any picture?
Jun 13, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Sony kdl46ex500 red power light blinks six times
Most probably there is a problem in the power supply and it is going on standby protection mode. You may have to search for a service manual from open websites and look through for the error code indicated by the led blinking, to be very sure. Unfortunately I do not have one with me.
Jul 07, 2012 | Sony KDL46EX500 46 in. HD-Ready TV
Sony bravia KDL-37XBR6 wont turn on at all, and blinks 6 times..
The 6X blink code is a bad back light error. could be one of the florescent bulbs in the panel if it shows a picture for a couple seconds and there is a darker band across the screen. Also Found loose connector CN6153 on the G5 Power Board.
CN6153 goes to CN6702 on the D4 board. Or the power board
Mar 30, 2012 | Sony Televison & Video
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
TLP2848Z blinking red, will not print
1: Is it a TLP2844 or a TLP2844Z.
Operationally they are completely different printers. TLP2844 uses ELP (Eltron Programming Language. but TLP2844Z uses ZPL (Zebra Programming Language). You need to calibrate the printer to the labels.
Calibration:
If its a TLP2844. Load media. Connect power.
Hold down feed key, power on, count one, two, release feed key. The printer will go through a calibtation routine and print config label. IMPORTANT - When it prints this label you must press the feed key and see the message OUT OF DUMP. Your printer will now be calibrated. Check this by hitting the feed key a few times and printer will feed one label each time feed is hit.
Calibration:
If its a TLP2844z.
Load media. Turn printer on and wait for green light (Approx 1 minute)
Press feed key and keep it pressed until green light blinks once, then twice, now release feed key.
Dec 22, 2008 | Zebra TLP 2844-Z Thermal Label Printer
TV won't turn on Sylvania LC320SL8 - 32'' LCD HDTV
will turn on tv with remote. stays on green for about 1 second and goes back to red.
Nov 11, 2008 | Televison & Video
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
Top Televison & Video Experts
Lawrence Oravetz
