Question about Aastra Telecom Aastra 9316CW Phone (16181)
The Number Pad doesn't work on my phone can't dial any numbers
Posted by morris_chris on
Anonymous
  • 3 Answers
Have a 1976 Mickey Mouse push button phone. I get a dial tone, but not able to dial out
This may be something as simple as REVERSING the line wires or a bad tone pad. Some pre 1980's tone pads didn't have polarity guard (EPG) and that's what we used to restrict dialing on touch tone lines (poor man's dialing restriction).
You can open up the jack the phone plugs into and reverse the red and green wires, or open up the phone and do the same thing. If it were my choice, I'd reverse the jack. If that doesn't fix it, pry off the faceplate cover over the dial, read the part number on the right side of the tone pad and post back. I'm sure I have an equivalent in the warehouse (outside of my 2 TT Mickey's) that I can give you a price on.
Carl
Jun 20, 2011 | Disney Classic Mickey Mouse Telephone
Why does vtech not have a speed dial? my son is
Programming Speed Dial Numbers
The handset must be OFF.
1. Press PROG. The IN USE LED will blink to indicate that you are in the programming mode.
2. Press the number of the memory location you wish to store the number in (0-9).
3. Using the dial pad, dial the number you want to store. The number can be up to 16 digits long. The number can be entered manually or by using REDIAL.
4. Press MEM to store the phone number
to the key you selected.
The phone now exits PROG mode and emits a tone.
Speed Number Dialing
1. Press PHONE to get a dial tone.
2. Press MEM and the memory location number key (0-9). For example, to dial the number you assigned to key '8', you would press PHONE, MEM, 8
May 27, 2011 | Vtech 9009111 Cordless Phone
How do I change the time on my Panasonic KXDT343?
1. From extension 101, press the PROGRAM key.
2. Then, using the number pad, dial *#1234 (Display shows SYS-PRG #).
3. Using the number pad 000.(Display: 000 DATE / TIME)
4. Press the SP-PHONE key (Display example:'93 Jan. 1 FRI).
5. Press the SP-PHONE key again (Display example: 12:00 PM 24).
6. Enter the new hour using the number pad.
7. If you need to adjust the minutes press the FWD/DND key.
8. Enter the new minutes using the number pad.
9. If you need to adjust the AM/PM press the FWD/DND key.
10. Press the AUTO ANSWER/MUTE key to select AM or PM.
11. When finished entering the new time press the AUTO DIAL/STORE key.
12. Press the HOLD key.
13. Press the PROGRAM key to exit programming.
Jan 11, 2011 | Panasonic KXDT343 Phone
Unable to dial any number from dial pad on my blackberry 9530. i can only dial 0.
Look for the solution here:
http://searchwarp.com/swa563532-Blackberry-Storm-9530-Keypad-Problem-What-To-Do-When-Your-Dial-Pad-Wont-Work.htm
Dec 30, 2010 | RIM BlackBerry Storm 9530 Smartphone
My touch pad not working probably, if i press the left most button on the pad the adjacent right button is activated for instance if i press 1 it 2 is getting activated. pls give me a solution for this. i...
That must be a hardware problem. Your touch pad need to be replaced with a new one. If your phone still covered with manufacturer warranty, you can have it repair free of charge. But if not, you can bring it to any phone repair shop to fix it.
Nov 04, 2010 | LG GD510 Cell Phone
Cannot dial a number..
you might need to eneter area code along with the number.
Jun 02, 2009 | HTC G1 Smartphone
Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed.
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
Nov 28, 2008 | Panasonic KX-T7730 Corded Phone
Cannot activate dial pad
Do a hard Reboot, Turn your phone off and wait 10 secs then turn it back on it should be fine.
May 03, 2008 | LG Prada KE850 Cellular Phone
Storing Speed Dial Phone Nmbers
Emergency/quick dial numbers: Pick up handset, push store, enter the phone number (it will not call the number), push store again, Push A,B or C. hand up handset. Frequently called numbers, pick up the handset, push store, enter the phone number, push store again, push key pad 1, or 2, etc. for memory location. Hang up handset. How to change a stored number. just repeat the sequence. How to clear a stored number, repeat the storage skip step 3 (do not enter the phone number). How to correct an error while storing, just hang up and repeat.
Feb 26, 2007 | GE Telephone pr521w
Lands Phones Logo
120 people viewed this question
Top Aastra Telecom Lands Phones Experts
Marvin
Marvin
k24674
Are you an Aastra Telecom Lands Phone Expert? Answer questions, earn points and help others
