Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
Posted on Mar 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Convergence problem Mitsubishi 6043
I like others have a blue bowed screen, I can adjust the red in all five positions and the blue in the center of the sceen but can ony move the blue horizontally in the corners. It wont move vertically. Any help is appreciated
Josh Whitehead
Level 3:
Genius:
  • Master 1,148 Answers
  • Posted on May 15, 2009
Josh Whitehead
Master
Level 3:
Genius:
Answers
1148
Questions
Helped
247531
Points
3024
DOES IT AUTOMATIC CONVERGENCE,,TRY THAT,,IN THE MENU,,TRY NEW JACKS
Mitsubishi WS-55805 CRT projection TV with
This problem is most likely caused by damage in the convergence output amp IC's; this model uses STK392-040. Fairly common for various fuses that protect the DC supplies for these amp IC's to open as well.
2helpful
Mitsubishi Convergence issue
If the screen is out of focus you probably need to adjust the focus on the focus block it is usually located behind the front grill, there are 6 adjustment screws on this block, leave the screen controls along just adjust the red, green, and blue focus screws. When converging a set everything is converged to the green, the blue and red are suppose to come to the green.
Bowing of picture at top and bottom towards center.
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
2answers
RED CONVERGENCE SCREEN PATTERN BOWING AND CAN'T ADJUST
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mitsubishi VS-50501A convergence problem. The image looks like a bow tie and the convergence will not align. This TV only has manual convergence. I already replace the STK391-020 ICs, it has 3 of them....
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
2helpful
Mistubishi Convergence/video display problem
*Screen Looks 3-D
*Colors wont align
Problem #2
Convergence
Did you remove 1 leg of each resistor out of circuit when you checked the resistors? sounds like thier is still one resistor open or maybe one of the new IC pins need abit more solder.
Red convergence is bad.
Hi, you need to change the convergence ICs , STKs: and some resistors,low values; , after changing them, you will have to go into the service mode, to do some adjustments.that's it.
Mitsubishi WS 55819 with a convergence
CEM-NO, BOTH ICS' WORK ALL 3 CRT YOKES.YOU EITHER NEED TO REALIGN THE RED IN FACTORY CONVERGENCE MODE OR YOU HAVE A RESISTOR THAT HAS FAILED.THE LATTER YOU MAY ACTUALLY BE ABLE TO SEE IF YOU LOOK CLOSELY.OH, ALWAYS DOUBLE CK. YOUR SOLDER CONNCETIONS.GOOD LUCK. JOE TV
2helpful
Mitsubishi VS 4552A
One of your convergence IC's has either cracked loose or burned out. The IC will have to be resoldered or replaced and then the convergence circuits realigned. If you do not have experience in repairing convergence circuits then have a qualified tech handle it for you. This is by far the most common failure in the projection sets and a good tech can have it fixed in about an hour and a half. I charge $150 for that but shops in your area will vary, so call around.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
