Usally there is in blue ''back up now'' when you open Retrospect Express and you can click it to start backing up files, that is not on the open screen. Also, the set up / restore button does not work, so I remove it and reloaded the software to be sure I had it in the computer
Windows XP correctly. It loads just fine except for the same problems described above. It's like it has no drivers to make it work from the software any more, so what can I do to make this work? I bought this unit in '06 and I only turn it on when I want to do a backup once a week. It's vital to my Home Office work in case my main computer goes down. Please get back to me ASAP > Carlos Messenger
SOURCE: Maxstor shared Storage II 500GB
Try mapping that drive as a network share under windows XP. This is done from "MY Computer" Map network drive. The set up your backups to back up the network drive you have created. If that does not do it then there is a contention between vista and xp as to the owner of the drive. Making the drive a mapped network drive should resolve this as neither should have ownership. Thats my best quess without knowing in detail your network setup.
SOURCE: Maxtor one touch software
John, try this link and see if it is indeed and newer version than what you currently have: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=Retrospect_Express_HD_Update_for_Maxtor_OneTouch-FR&vgnextoid=f0ce8b9c4a8ff010VgnVCM100000dd04090aRCRD
Hope this works out.
SOURCE: No backup option at all. Hd express loaded etc..
try going to this site this is the latest maxtor backup software
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=retrobackup&vgnextoid=c6773428ab622110VgnVCM100000f5ee0a0aRCRD
SOURCE: Maxtor Basics 500GB Hard Drive MXT3002
is your drive normally detectable in system? if yes [it has a letter asigned] run command prompt and cd /D <drive letter> chkdsk /r if asks to unmount say yes then reinstall backup program
I am experiencing the same problem. Running diagnostics found no problems with the external drive. I've uninstalled and reinstalled the software without any issue twice. However, the problem still exists.
Any help would be appreciated.
Thanks,
Beth
