The lens on this camera is a fixed-style zoom lens. It is not removable. If it "fell off" when dropped, the better term would be it "broke off" when dropped. Probably toasted.....
I assume you've tried removing and re-seating the batteries in the remote. If this doesn't reset the remote the fall most likely broke a component or solder point on the circuit board. If all else fails you can try opening the remote and making sure no wires are broken. Look closely around the battery contact points. Often when a remote is dropped the weight of the battery can cause damage to that area.
No, machine keeps running, but lamp is out. This is cool down cycle. Dont turn it off. It will vary from 15 seconds up to 2 minutes. This is pretty normal.
Not really sure what you are asking? Is it a thermofax that is making noise that you use to make transparency with. Or is it transparency making? I never worked on a transparency maker in 20 years of office machine repair... What is it? Is a old machine? If it is that old it may be time to replace it....
No. This feature requires a light source to shine light through a slide to the lens so the image can be copied. Your Canon all in one doesn't have a transparency top that shines light through a slide. I had to get an Epson Perfectin scanner with transparency top to copy my slides. Hope this helps.
oops..that's not going to help out too much. I'd say that your printer is really going to need some professional onsite or depot help. Dropping any computing device will upset it's mechanicals dramatically.
