Park the Canyon on a flat stretch of road or driveway and open the hood.
Remove the master cylinder cap located near the firewall on
the right side of the GMC's engine. Remove half of the brake
fluid in the reservoir with a turkey baster. Lay the cap over the
container.
hi sounds like good advice with out your rear brakes working properly all the load will be transfered to the front brakes causing uneven braking and in wet or slippery conditions front wheels will start locking up causing lose of control
Is the piece you are referring to the piece that holds the brake pads? If so there should be two larger head bolts behind that piece that holds it on to the front axle.
Hello, raise the vehicle, support it with jack stands. After taking off the wheel remove the caliper upper and lower screws, than remove the caliper support and the rotor should come off.
Jack the car up in the air and get it safely on jackstands.Then remove the front tires.Remove the calipers and caliper mounts.Then remove the center bearing cap, next remove the bearing tension nut, then the outer bearing will fall out with the washer.Last step is to firmly tug on the rotorand then remove the bolts in the center part of the rotor to split it from the hub.
It will come off try heating the area where the thread is with a small hand held torch it probably has loctite on it get the thread area hot and it should come out.
