This link to Dell's support site should help you figure out how to open the case whether it is a tower or desktop. This article comes with images and will show you everything from the assembly/disassembly of the cover, front panel, drive cage, motherboard, CPU, etc.
Hope it comes in handy and don't forget to bookmark the page!
SOURCE: how to remove cover on
Slide the plastic "L" in the back down (facing the back of tower it will be mid right) while holding the "L" down slide the side cover towards the back (facing the back of tower it will be the right side cover) It may take a little persuading!
SOURCE: How to open dell 4300 dimension cover
to open the case, which lies open like a book after you
place it on its side. Closing it was also tricky, as cables got hung up on
internal components.
This machine is middle-of-the-pack by most
performance measures. Equipped with a 1.5-GHz Pentium 4 processor and 256MB of
SDRAM, it posted a score of 94 on our PC WorldBench 4 tests, about what we've
seen from other 1.5-GHz machines running Windows XP Home. The 17-inch Dell
M781S monitor displayed excellent 12-point text at 1024 by 768 resolution. Our
color photo of a group of children looked sharply focused, although its colors
could have been more saturated. The Harman/Kardon HK695 audio system's two
slender, champagne-glass-shaped satellite speakers were surprisingly powerful
for their size, but the black subwoofer sounded somewhat weak. And
disappointingly, game play broke down at a resolution of 1280 by 1024 with
32-bit color in our Quake III and Unreal Tournament game tests. Our judges
awarded only middling scores for image quality in both games at 1024-by-768
resolution.
While not a powerhouse or a high-end multimedia
center, the Dimension 4300 remains a reasonably priced all-around family
system.
SOURCE: How to remove tower cover...
There are going to be a few small screws on the the back right side (if you are looking at the back of the tower. Remove the the screws from along the edge of the side ( you may have to loosen both sides ) and the case slides towards you then lifts off. If it doesn't budge use a flat head screwdriver to pry in between the cover and tower case and gently slide it towards you. Trust mr it won't break cause it's metal and if it bends you can use pliers to bend it back to shape. Hope the info helps GOD Bless You.
SOURCE: Cover removal Dell Dimension 4600 Desktop
Description of how to remove the cover for this model can be found at the following link:
http://support.dell.com/support/edocs/systems/dim4600/en/4600/sm/remcvr.htm#1084976
SOURCE: unable to remove cover from dell dimension 8400
This Dell Support, and the Service Manual for the Dimension 8400,
http://support.dell.com/support/edocs/systems/dim8400/SM/index.htm
In the Service Manual main menu, left-click on - Opening the Computer Cover
1) Computer off, and unplugged from power. (Always unplug the power cable from the surge protector. Then if the power cable needs to be removed from the computer, do so)
2) Remove all cables to the computer
3) Lay the computer on it's Right side.
(As you face the computer, your right side is the computers Right)
4) There is a Release button on the Top of the computer case, and a Release Button on the Bottom of the computer case.
These are located at the Rear of the computer.
The preferred method of opening the computer case, is to press one release button in at a time, and slightly lift up on the side of the computer case, where that release button is located near.
Then go to the other side of the computer case, press this release button in, and lift up on the computer case.
The computer case opens like a clamshell. The computer case is hinged at the front.
Example:
Computer laying on it's right side. Press the Top release button in, and lift up on the computer cover located near the Top.
Now press the release button on the Bottom. Lift the computer case up.
The computer case opens from the back, towards the front, like opening a car hood.
