Epson Dot Matrix LQ-590 Printer Logo
Posted on Mar 27, 2009
Epson LQ 590 Label Problems
Using Corel Wordperfect label program, first label prints fine, but others are not centered correctly on the label. Okidata 590, previously used, worked perfectly and we are at a loss for solution. Attempts to change page setup margins, etc. failed so far
Michael
Level 1:
  • Contributor 24 Answers
  • Posted on May 26, 2009
Michael
Contributor
Level 1:
Answers
24
Questions
0
Helped
12101
Points
38
Make sure the option for bidirectional printing is set correctly.
Try it both ways
Make sure you are not printing too far to the left or the right - the print head can hit the end of its run and lose its place.
5 Related Answers
Jessie Goss
  • 162 Answers
  • Posted on Aug 06, 2007
SOURCE: okidata ml390/391 Turbo
you have to set this on your computer. when the print box comes up you need to choose the label catagory to make your printer print labels just right
Anonymous
  • 150 Answers
  • Posted on Jul 18, 2008
SOURCE: epson LQ -590 PRINTER PROBLEM
  1. You text page is larger than the printer page,
    margins are set wrong, or there are special
    formatting marks and/or characters at the end
    of your documents.
  2. Check default printer paper-size settings:
    START --> Printers & Faxes -> Chose printer -->
    right-click --> properties --> ....
    This sets the default settings, that are in effect every time
    an application starts up.
    Also note, that if printer settings are not listed within
    your START menu, you can find them in the Windows
    control panel. You can change what shows in the
    START menu and what doesn't by right-clicking the
    task bar.
  3. Now start your application and do the same thing under
    the file menu:
    File --> Print --> Settings ...
    File --> Printer settings ...
    File --> Page setup .... and also margins. etc...
    This sets the actual settings for this application or the
    current document. These settings over-ride the global
    default setting in item (2)
  4. To clarify, the settings in item (2) should be setup to
    reflect the way you use the printer the most often.
    The settings in item (3) reflect the actual document you
    are trying to print now.
  5. Be careful that the paper size settings (3) accurately
    reflect the paper in the machine, do not confuse
    metric sizes: A1, A2, A3, A4, A5 ....
    with English sizes: Letter, Legal,..... etc
    These do not line up exactly.
  6. Also check your document, to make sure that there
    are no extra characters at the end of your document:
    Paragraph marks, Page Brakes, Form Feeds, etc.
    Also check the paragraph settings (in Word for Windows,
    for example, to make sure that is not the cause of the
    problem.
    In word for Windows, for example, you can also go
    into tools, options and change the way your document
    is displayed, such that all formatting marks become
    visible (or click on the paragraph tool)
  7. Finally, most Windows applications offer some kind
    of print PREVIEW facility, so that you can see what
    you are going to get, before you physically print it.
I hope this solves your problem, please rate my answers.
Good luck.
Martin
A
Anonymous
  • Posted on Aug 26, 2008
SOURCE: software was written for Dymo printer
Firmware for Printers
Anonymous
  • Posted on Dec 11, 2008
SOURCE: HP Deskjet F2180 Margins incorrect for label printing
I eventually managed to print my labels one sheet at a time by forcing the label top edge down the page. You can insert one or two lines above the label template and adjust the font size to get the right distance. It took a bit of trial & error but got there in the end. Hope it helps you
doubee
  • 128 Answers
  • Posted on Oct 18, 2010
SOURCE: How do I print just
I assume you are using a sheet of labels, such as the typical 3 x 10 sheet. Word sets up the mail-merge document for printing the whole sheet, so if you print just one or two labels, you will `waste' the rest.
One way of using that sheet over is to create a mail merge that contains blank `dummy' addresses. It is rather involved and at best time consuming, and considered not worthwhile to save a partial sheet.
I service printers, and personally do not recommend that any label sheet be re-used. The printer curls the paper, in some cases fuses it, and causes the corners of the labels to be exposed, and possibly get caught in the printer (I have removed a lot of labels from inside printers)
2answers
How to print only one sheet at a time not all sheets
This can be a little tricky. If you haven't used any of the labels yet, simply put the address in the first label and simply print. The printer will print the address on the first label and all you have to do is remove it and put it in place. Next time you need to make another label, set up the program that you are going to use to print the label and once the "Avery 8168 Inkjet" label is on your screen just move the cursor to the second label (With Corel WordPerfect just hold the ctrl key and hit the Enter key) and print your return label. Using this procedure you can use one sheet of labels without having to print all labels at once or using a new sheet.
How do I print just one mailing label without running through an entire sheet time I print using an Epson LQ-590 and printing from the mail merge option in MS Word (MS XP)? In other words, when I print...
What are the nos of lines that are printed using LQ 590 with paper size - 21 x 30.4
Hi
Register to epsonexpert.com so you can get the technical details for it. Hope this helps.
5helpful
2answers
WordPerfect only prints to manual tray on Brother HL-5370DW
Close WordPerfect. Clear all printers. Go to Registry Edit and browse to HKEY_CURRENT_USER\SOFTWARE\Corel\14 or whatever version you are using and right click on the "PrintEngine" folder and rename it, e.g, "PrintEingineOld." I discovered this shortly after I posted my inquiry.
2helpful
Epson print LQ-590 always paper jammed at roller when printing continuous 5 sheet of paper. May I know how to fix this?
the paper you are using may be moisten. pls try another paper sheets . purchase new papers.
if the problem continue clean the paper feeder assembly roller with moist cotton using cleaning liquid eg petrol or spirit etc.
Epson model CX4800 - will not print anything from "word"
I can't say I've experienced this problem myself but a little google searching indicates you are not alone.
The problem is not your printer but WordPerfect.
This troubleshooting document may help:
http://corel.custhelp.com/cgi-bin/corel.cfg/php/enduser/std_adp.php?p_faqid=754014
My guess is that the steps titled:
- Restore WordPerfect stored printer information
Add the Print Engine to the Startup Folder
- Enable Bidirectional Support for the Printer
... are going to be the most relevant.
Hope that helps.
1helpful
Not Printing Correctly
Try reinstalling the printer driver using the CD with label on it LX-300+.
LQ 590 POS
the driver for your printer is not installed correctly. please reinstall.
First line not printing
It sounds like you are trying to get too much onto the labels or onto a sheet of labels. Try a few pages with a size smaller font and if that solves the problem, the issue is too much info for the epson to fit on.
WP will push the limits of any printer if you make it do so like this and the printer maker may have rounded the specs in the driver.
Update your driver.
Try changing from inches to cm or points etc to see what the limits are.
Then respect that the printer can do no more with that particular driver.
Good luck
Michael
1helpful
2answers
Printer dropping every 12th label
Probably not the printer but the print spooler in the computer has not the capacity for more then twelve and has to 'reload' Get the computer RAMemory checked or increase the size of virtual memory Anoth solut and not difficult to organize is to print the lables in batched of then So you will have[for 500]50 pages to load print ten load a page etc.,
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
