Pantech C300 Cellular Phone Logo
A
Anonymous Posted on Jul 04, 2013
Insert sim - Pantech C300 Cellular Phone
Insert sim card
Do you want to insert other network sim or if your Blackberry Curve 8350I displaying insert sim card,if already sim card inserted.Don't worry i will help you.You can insert other network sim card in the phone by unlocking the phone from current network lock.To unlock Blackberry Curve 8350I use unlock code.Visit the site Wickedunlock.com get unlock code and unlock it easily.Then insert any GSM network sim card.If the phone displays insert sim card even though sim card is already in the phone.Please remove the sim card and replace it correctly.It is because the phone didn't detect the sim correctly.After inserting if it is display invalid sim or sim not valid message on the screen.It is locked to some network,you need to unlock it.To unlock use unlock code.Get code from online site and unlock it.
9helpful
3answers
Sony ericson t303 insert sim
Hi the sim contacts in the phone try praising them up a little
2helpful
Insert smart sim
Insert sim error happen if the phone is not acknowledging the existence of sim card inserted in the phone.
1. Check if the sim is properly inserted.
2. Turn off mobile phone
3. Remove battery
4. Remove memory card
5. Remove sim card
6. Check the copper pins of the sim if there are dirts stucked on it
7. Ure clean cloth to wipe sim gently
8. Wait for at least two minutes
9. Gently and properly insert the memory and sim card
10. Insert the battery
11. Turn on mobile phone
13. Check if you will still recieve insert sim error
14. If you still recieved the same error you need to call your service provider and check the status and availability of your sim card.
When i insert my simcard to my phone always say insert sim what should i do with my problem in my sony ericcson k610i?
If that was the message that comes out on your phone after inserting the sim card,Its just means that it is not properly inserted.Try to make sure that it was not inserted in other way,upside down.Try to rechecked the With the metal contacts facedown, align the notch on the SIM card with the notch on the SIM slot and insert the SIM card.If also means that the SIM that yuo are trying to insert has been used and has password on it.Try to insert the SIM to its original phone and unlocked SIM codes.Previous codes has been entered on it.If that is a new SIM there might be problem with the SIM slot.try another SIM card to diagnosed the real problem..Hope this helps..
2helpful
2answers
Samsung Geino, my sim is inserted but my phones keeps saying insert sim i carnt phone anyone blah blah help
Hi,when a phone keeps saying insert Sim card, is either the Sim card has problem or the Sim tray of the phone is bad and will need tobe replaced.
To confirm, Take the Sim card and insert it into another phone, If it still says insert Sim, that means the Sim card is bad, But if the Sim card works with another phone, That means the Sim tray of the phone is damaged.
Sim tray is located on the phone where you insert your Sim card in on the phone to make sure the Sim works with the phone.
Have a nice day.
Sep 12, 2010 • Cell Phones
Ive inserted a vodafone sim card in sciphone, phone sayn insert sim. also why is there 2 sim card slots?
This is called Dual sim phone. Go to settings and make sure that the Dual Sim is enable. Whe a phone state "Insert Sim" after inserting the sim card, it is most probably that you had inserted the sim the wrong way, so that the gold connectors is not connecting with the phone. Invert the sim card and try. If the problem persist, try the other sim slot.
2helpful
2answers
2helpful
2answers
Sim card
Sounds like phone is locked or firmware is bad
5helpful
2answers
Insert SIM Card message in nokia 6080 though SIM is inserted
May be its detecting your sim card properly. Check your sim card in another handset. Verify if its the propbelm with sim card not your handset.
Top Pantech Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
