Question about Philips Vacuums
I NEED A TELESCOPIC HOSE FOR MY PHILIPS EXPRESSION HOOVER, WHERE CAN I GET THIS MY HOSE PIPE IS BROKEN AND I HAVE TRIED TO GET A NEW ONE AT VARIOUS SHOPS HERE IN IRELAND AND I CANT.
Posted by loretta_phel on
Ryan S
  • 328 Answers
Hi - greetings from Scotland! Im not sure if you mean telescopic hose = do you mean telescopic metal tubes? If so they are readily available on ebay.co.uk I buy from many sellers on there but Hoovermania are one of the best.
What you need to do before order is to measure one of the smaller cleaning tools at the opening with a ruler where you'd usually put the hose. If you haven't got one to hand measure the end part of the plastic handle where the hose is where you'd usually attach the pipes. Generally if it measures 3.5 cm this works out to be a 32mm fitting tube which is readily available on Ebay and from different sellers. If however it is more then it has a 35mm fitting.
If its bigger than that, then you'd need 35mm tubes of which some are still available on EBay. In any case, you can look at different manufactures because when it comes to telescopic metal tubes the 32mm fittings will fit any vacuum cleaner that can accomodate these sizes. Therefore shop around; Hoovermania have a few on offer and you can phone / email them if you are not sure.
Posted on Mar 27, 2009
How do i replace a valve assemblyon a hoover widepath f6020
You don't need a new hose. Remove the two Phillips head screws which hold down the wand cover. Be very careful when removing these parts. Pay close attention on how these parts are assembled. They are spring loaded and will fly out the end of the hose assembly when the cover is removed. The wand valve assembly or the nozzle valve assembly or usually the parts that break. Vac Parts Warehouse Here is a link of the parts breakdown.
Oct 12, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover telescopic handle broken
What is your model number?
It's usually located on the left side of a a silver sticker.
Nov 05, 2013 | Hoover Vacuums
My Hoover Linx handle broke.
Not sure what you mean by a broken handle, but if you mean the plastic is cracking where the handle connects to the main body than I have a suggestion. We have had this happen a couple times and I tried various fixes that did not work. However, recently I found a cheap product that will strength the handle to make it stronger than new. It called Fiber Fix tape (its on Amazon). Wet the tape and wrap the handle. It is a quick set epoxy in a fiberglass like cloth. Dries very hard. Not pretty, but it works great.
Jun 19, 2012 | Hoover Platinum LiNX Cordless Stick Vacuum
Hello! Hoover WindTunnel broken! aRGGHHH
I would definitely check out the epoxy route.
Jun 14, 2017 | Hoover U6630-900 WindTunnel Bagless...
Hi, I have a Hoover Hotshotz vacuum cleaner, The plastic connector that joins the hose to the chromed metal pipe has broken. Any idea were I may attain a new one? I live in Perth. Regards Gary
Hi there Gary, SmartAlec from NelsonVacuums.com.au here. I can help you with that but first i need to know if you have the newer hoover hotshotz (less than 5 years old) or the one that would be 10 years plus?. Also there was a new one with powerhead and a standard version. If you can shoot me the information via email [email protected] i can ship one this afternoon. Or call my shop on 0269215200.
Aug 25, 2009 | Hoover Vacuums
Lower hose broken hoover agility how to replace
to replace a hose on the Hoover V2 is a pain in the you know what. i would recommend
1. take it in and have a professional repair shop do it.
2. trade the V2 in for the Hoover PowerMax steam cleaner with spinscrub they are 100X better then the V2's and about 1/2 the price
Jul 28, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Vacuums Logo
217 people viewed this question
Top Philips Vacuums Experts
Tim Venetis
JonSnell Electronic
JonSnell Electronic
Attique-ur-Rehman
Attique-ur-Rehman
Are you a Philips Vacuum Expert? Answer questions, earn points and help others
