How do I set the photocopier to print from network? On the computer add printer wizard does not have Ricoh aficio 1013F listed. How do I solve this problem?
Hello sir;You may go to SP mode to print out default setting list;
Press "clear mode" key then enter107 then press and hold down "clear/stop" key, touch on screen for "copy" then press 5992 hit enter, touch 0 to print out the standard setting list, turn off the copier when you finish.
Is this actually a Ricoh Aficio 1013F, or another model, because "CH551" is not a ricoh service code?Do you mean "SC551" If so, this is a fuser "triac" problem (basically a fuse in the heater unit). It can only be reset in service mode after the problem is fixed...and will require a tech.
If you already have wireless setup easiest way is to purchase a wireless bridge, gives you wireless connection with hard wired port to connect to the copier. Configure the bridge to same wireless settings as your network and plug cat5 cable from machine to bridge setup print driver and you are golden,
It needs to be added within the printer driver. In The Printers/faxes dialog box, "right click" the "Aficio 1013F", click "properties" click the "accessories" (or "change accessories") button, and add tray 2 as an option, Click "apply", and exit the utility, now you can manually select tray 2 when printing.
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
I do not have a cd where can i download it from
