Question about Panasonic VIERA TC-P55ST50 55 in. 3D Plasma HDTV
Stuck on 480i with Panasonic HD Plasma
I completely understand the comment about the signal input driving 480i or 1080i. Is there such a thing as True HD TV channels? I can't seem to move to 720 or 1080, even with HD channels. System Components: Panasonic 55" HD Plasma TV (P55ST50) DishNetwork HD DVR (622DVR) Component Cable connection HD Input on Dish DVR set to 1080i HD package from DishNetwork Your suggestions are much appreciated!
  • Panasonic Master
  • 6,694 Answers
It sounds that a software update is necessary. Contact the service centre for Panasonic, to get the latest software to this model Plasma tv.
Posted on Jul 04, 2013
6ya staff
SOURCE:
Martin Murray
  • 1623 Answers
SOURCE: Panasonic Plasma Monitor TH-42PWD7B - Convert to TV screen?
hi yvonne not sure if you sorted this but using this lead should get you sorted
http://www.maplin.co.uk/Module.aspx?moduleno=4702
the phono blugs ae used for audio and bnc plugs on the back of your panny are for the video
Posted on Oct 28, 2009
Anonymous
  • 245 Answers
SOURCE: TV- some channels don't have any sound, other channels do
RE TUNE UR TV AGAIN AND LET IT FIND ALL THE CHANNELS.......IF PROBLEM PRESISTS CALL PANASONIC SERVICE AND TELL THEM OR PROBLEM U HAVE IM SURE THEY WILL TELL U WHAT TO DO .........OR MAY OFFER U FREE SERVICE......WHAT WILL BE UNDER THE WARREN TIE U HAVE FOR 12 MONTS
Posted on Nov 20, 2009
Anonymous
SOURCE: Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Posted on Feb 20, 2010
ilonchik15
SOURCE: Sony Viao HDMI to Panasonic Plasma TV HDMI Input handshake
My TV turns off while watching and message pops "Plasma no signal " . Please tell me what to do . Thank you
Posted on Jul 11, 2011
RobT
SOURCE: Wii hook up with my Panasonic tv
Simply plug the yellow, white and red plugs into the INPUT 3 ports on the front bottom of your TV. Use your TV/Video button (either on the remote or next to the INPUT3 ports) and select scroll to the Video3 option. Ensure that the 3 plugs are firmly pushed into the ports. My initial problem occurred because I thought they were pushed in all the way, but they weren't. You do not need to have your tv on any specific channel for this to work.
Posted on Dec 23, 2011
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
How to I change tv to 1080i from 480i?
this should automatically be done by the tv. If you input to a standard def input (ie yellow plug) or are using standard def cable it will be 480. If u change to a HD input or an HD channel it should automatically switch to 1080. The input displayed on the tv that says 480i or 1080i is just a result of what is being played, not a setting to be changed.
May 11, 2010 | Vizio VX37L Television
TV only formats at 480i
Check in your instruction manual to see if the set can actually work in 1080i. Most of the sets going back about 4 to 6 years ago were not capable of working in 1080i.
The signal coming to your Sat box may be in 1080i, but your Sat box has to be able to output 1080i. This can be quickly verified by calling the support for your service and giving them the model number of their Sat box.
Jerry G.
Dec 16, 2009 | Mitsubishi WD-52525 52" Rear Projection...
1080P video via HDMI generates awful interference
Your Plasma's native resolution is 720P. Go into the Blu Ray's output setup. you can choose 480p 480i 720p 1080i and 1080p. Set it for 720p that should clear up the issue.You may have to run Component directly to the TV since you only have 1 HDMI input and you can run Digital coax or optical to your AV receiver for audio. On a 50" TV the difference between 720p and 1080p using "GOOD" cables cannot be seen by the human eye. Above 50, yes it is noticeable.
Hope this helps.
May 22, 2009 | Onkyo TX-SR705 Receiver
Adjusting the resolution from 480i to 1080i
Typically TVs will auto adjust to the input signal it receives. If your cable box is only outputting 480i then all the tv will show is 480i. Ensure you have a good 1080i signal going in to the unit and check again
May 04, 2009 | Televison & Video
1080i
According to specs, the PLTV-32 supports up to 720p.
That's essentially the same as 1080i, and should work with a 1080i signal.
Mar 19, 2009 | Spectroniq Protron PLTV-32 32 in. Plasma...
Want to change my sharp hd tv from 480i to 1080p
You Can Not Change. The TV Recognize the signal on the INPUT.
If the signal is 480i than the tv shows 480i
If the signal is 1080p than the tv shows 1080p (if supported)
If you try with your areal antenna (for now digital broadcast is maximum 1080i (in USA) The TV itself doesnt "upconvert" lower resolution signals.
Dec 18, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Daniel
It'll still be 480i, it'll just work on a 1080i input now. You can't make HD out of a non-HD source.
Geno
Jan 24, 2008 | Televison & Video
Sharp LC-37D4U 1080i picture problem
have the cable company set the box to 720p whic is the native resolution of the set.this will help with quick signal adjustment
Dec 29, 2006 | Sharp LC-37D4U 37 in. LCD Television
Panasonic VIERA TC-P55ST50 55 in. 3D Plasma HDTV Logo
443 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
