There is a little plastic lever/flag which detects the paper at the
rear, just after the heat section. I think on this model it can just
about be seen by opening the rear door, it should be in the middle of
the black lower paper guide section. The "flag" should be protruding
slightly to be activated when the paper passes. However if it is stuck
down (hence giving you false paper jam message) it will be more
difficult to see! Use a decent torch to help see. Hope this will help you.
Carefully check for any paper stuck in the system. Does the error go away on reboot? or is it constant? Does the error occur every time you print or just sometimes?
Most likely power supply. These Samsung 2000 series laser printers are notorious for bad capacitors in the power supplies. Pretty simple repair IF you can get a good tech who can pull out the power supply (not hard) and replace 5 capacitors on the power supply board. A good price to pay would be in the $100 range for parts and labor.
The plastic paper guide where your paper exits the printer is stuck in the up position triggering the sensor. Push the plastic guide down and it should solve the problem
I have the same problem with ML-2251N. The message is "internal error tskcrum 0203".
I have same problem with the printer Samsung ML-2551N and it appear internal error TSKCRUM 0203
Internal error mdlcrum 0094 in samsung printer ml-2550
TROQUE O CHIP DO TONER
