Even though I have the printer set up to fit the 5 x7 sheets, if keeps printing like the page is 8.5 x 11. Therefore the sheet comes out with only half the page printed on it in the far right side. I have checked the page set-up and it is set for custom sized piece of paper 5 x 7. What am I doing wrong?
SOURCE: Paper completely wrinkled
I have two HP LaserJet 1300n printers and like all printers after use (or misuse) they will need PM or repair. The problem with the paper wrinkling is easy. If you have worked on printers then you can make the repair for about $8 - $20 and a couple hours. You can find the service manual at HP's website or online. It is typically a roller or the fuser film is torn. Disassemble the printer/fuser in accordance with the service manual or break out pic, clean, replace part and reassemble. For those who do not want to DIY then you can buy the entire fuser assembly on multiple sites anywhere for refurb w/core exchange to new for $70 - $150. The printers are good printers but like all mechanical devices, they will fail...it's just when and how.
SOURCE: laserjet 3015 is printing multiple pages on one sheet
exists special function in driver of the printer which quantifies pages of the document on one signet sheet. Sounds like "Multiple printing" you can manipulate or disactivate this function.
SOURCE: Can not figure out how to print on any custom size paper
If you go to your printer properties, preferences or advanced, on the Main menu, is paper sizes,
click the little tab, look at the sizes list,
scroll to the bottom, and you will see.
Custom sizes by User, create your User Defined cusom size.
check your paper tray is setup correctly.
should be good now.
Regards
Richard.
SOURCE: Extra blank sheet of paper between printed pages
Check your print settings, it is possible that you enable page seporator in the settings.
SOURCE: Problem Printing Sheet Paper with the Epson 9800
On the machines control panel set to sheet fed (pressing the left button will change from Sheet, roll and roll with cut). In the print settings select your paper profile. On the page setup choose sheet. In the pull down menu you should only have basic paper sizes, no custom size. choose 20x30 and try again.
let me know if this helps
