There are several ways to find the cube root of a number on a calculator. On this calculator, we can use the nth root button, by using the yellow shift button with the ^ key. Another way to do this is just to use the ^ key.
For example, the cube root of 8 is performed by the following key sequence: 8, shift, ^, 3.
The nth-root function is the right-shifted function of the square-root key, second column from the left, fifth row from the top.
In RPL mode, to calculate the third root of eight, press 8 ENTER 3 right-shift [nth-root] and get 2.
In algebraic mode, press right-shift [nth-root] 3 right-shift [,] 8 ENTER and get 2. (The comma is the right-shifted function of the SPC key on the bottom row.)
Square root of 39: Press 3 9 [square-root] =
[square-root] is the key just to the left of the divide key.
Cube root of 9482: Press 9 4 8 2 2nd [cube-root] = [cube-root] is the shifted function of the 0 key.
For other roots, you can use the [nth-root] function, the shifted function of the key above the divide key. For example, to calculate the fourth root of 16, press 1 6 2nd [nth-root] 4 =
A power is just repeated multiplication, so without a calculator you can work the answer out longhand. (If you were trying to do the nth ROOT of a number that would be much harder!)
Any number N to the power P, then, is N multiplied by itself P times:
The structure of a number in scientific notation is as follows one digit [decimal mark] several digits power of 10 (- sign if needed) up to two digits for the exponent. d.ddddd [10^] (-) dd
To enter a number in scientific notation you need to use the [EXP] key, between the [.] and the [=] sign, on the bottom row of keys.
Ex: Avogadro's number (do not worry if you do not know what it represents) Na= 6.02 x10 ^23 6.02 [EXP] 23 [=]
Electron charge 1.6 x10 ^(-19) 1.6 [EXP] [+/-] 19 [=] The [+/-] key is the change sign key, in the first column of keys, between the fraction key [a b/c] and the [7] key
Hello, If there is no special key reserved for that operation, you can use the raise to an arbitrary power key. This key is represented as [^] ( a caret or accent circonflexe) or [X to the y] or [Y to the x ]. I have just verified : it is primary key accessible directly. If you want the cube of a number; 2 [^]3 =2x2x2=8. In your algebra course they must have taught you that the roots of a number (square, cube, fourth, fifth, nth) are equivalents to raising that number to a fractionary power (a power whose exponent is a fraction of the form 1/2 ,1/3, 1/4, 1/5, 1/n etc.)
