I have a 61 inch panasonic LIFI. When I turn it on the green on light flashes but the TV does not actually turn on. Eventually the red off light begins to flash. Any suggestions?
I had the same problem, turned out to be the bulb, had it replaced and now I`m having problems with the new bulb (dark picture).By the way the first bulb lasted only 8 months and it has been 8 months since the new one was put in, so much for the 5 year bulb.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience
All the troubles I've seen with this model are because of the LIFI lamp. Panasonic warrants the lamp assembly for four years from date of purchase. Call Panasonic toll free hotline or go online for an authorized warranty shop. Good luck
I have the same problem with my Panasonic PT56LCZ70, after check the test points, I'm sure its the "LIFI 4000" Lamp, and I think its a faulty part in all kind of those Tv's
If the light is flashing 2x and pausing and repeating you probably need a new lamp.Panasonic has extended the warranty on the labor for the lam p to 3 years due to difficult replacement.Call Panasonic customer service and they will refer you to the nearest service center.The lamp itself is covered for 5 years.
