On my Roper stylemaster top load washing machine I can hear the motor spinning but the agitator doesn't spin at all. I bought this machine in 1999 and it has never given me any problems. Is it belt driven or gear driven? I can't see a belt underneath unless it in inside the casing that holds what I am guessing is the motor. I don't want to waste alot of money on it if it is going to be very costly. Thanks for any help.
Probibly a coupled drive. motor coupling runs everything, pump,aggitator, spin. if none of these thrree, coupling is two plastic parts with rubber between directly on the shaft of the motor , see if there are two screws at the bottom of front of case., if so remove aathen look for clips at top rrear this should be an easy fix
