Hi I have problem ith my sandisk , when I try to recover sd card there is phrase tells me(no data found )so how can I fix this problem
SOURCE: coping pictures from computer to mocro sd memory card
How do you format it to mach your phone?
SOURCE: USB port broken in 1TB seagate Freeagent external hard drive
Yes you can just take the hard drive out of the case, can use it with any other case, you can also just put it inside your computer and connect it to the sata cable :)
Heres a case you could use for your drive... Click Here
Please rate
Many thanks
SOURCE: I am trying to use my SanDisk mobilemate SD + can
Plug the SanDisk into the first computer. It should show up as a disk drive. You can drag&drop files from your computer to the SanDisk the same way you copy files around on your computer. Then remove the SanDisk (depending on the operating system, you may have to "unmount" it first) and plug it into the second computer. Drag&drop files from it to the computer's hard drive.
SOURCE: how to recover data from corrupted hard drive?
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this file recovery program called asoftech data recovery to recover your files.
http://www.asoftech.com/articles/free-data-recovery-download.html
SOURCE: cant initialize drive to recover
first, recover your files. You will need to use something like this data recovery program.
http://www.facebook.com/pages/Asoftech-Data-Recovery/290956907592436?sk=info
After you get back your files, you can then format the drive and reinstall your system.
