Kenwood KVT-M700 Car DVD Player Logo
Posted on Mar 27, 2009
Kenwood kvt m700- playing cds
I have a kenwood kvt m700 setup in my car that is connected to a seperate dvd/cd player... when i put in a cd, the music will start playing but i seem to have no control over the music aside from the volume which i use the physical up and down buttons on the kvt m700 unit to control... the source to recieve audio from cds and dvds is known as "video 2" on my kvt... there are no onscreen control buttons such as pause play or next track.. and there is no "cd" source option...
in the manual it shows screen shots where "cd" is an actual source option, and the on screen buttons music control buttons are shown as well... why doesn't my kvt m700 seem to have this source option? and how am i able to perform such basic functions as changing tracks??
also i put int a dvd as well and it runs just fine, sound and picture... but once again, there seems to be no way for me to actually start a movie or select different options on its main menu because there are no navigation buttons that appear on the touchscreen...
does anyone have any suggestions?? this unit is so complicated, if i don't figure out these basic things i might just switch to a standard, NO NONSENSE cd player although it might cost a little bit to get this uninstalled...
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Jul 21, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
2397
Points
7
The M700 is purely a monitor so you will not be able to control play, pause, stop, skip, FF or RWD. I use my DVD player as a CD player and have to use the DVD remote to change tracks.
The kenwood kvt-m700 doesnt have a place to play dvd's or cd's right? you have to use a seperate cd-dvd player and plug it into the dash unit ...(RIGHT) WHAT WOULD B the correct type to get and what inlets...
Hi
Guess your car's wires haven't been cut. Go to any stereo shop and get the harness that's specifically for your car. The colors on it will match all the colors on the clarion harness. Connect like colors, plug in, and you're done.
Please check the below mentioned site for the wiring diagram which will help you for the installation.
http://www.tehnomagazin.com/Auto-radio-car-connector/KENWOOD-Car-Radio-Wiring-Connector.htm
please let us know for further query.
Thankyou for contacting fixya.com.
2answers
Kenwood kvt m700 touch screen problems
You don't need a code, it's unlocked by the remote that came with the unit (small purple one)
I have a kenwood kvt-m700 dvd player that gets sound but no picture when i try to play a dvd
The only way to play DVD's on your M700 is to have the handbrake on. Although you can get round it by plugging the DVD into the second set of connectors (AV2) instead of the first (AV1).
I have kenwood kvt m700 screen bottom half dont work please help
Sounds like the board inside the unit is on it's way out.
Kenwood kvt-m700 security code problem
You can send it off to a company on ebay who will de-activate the code for the stereo.
Freeway indash DVD
u need to switch function screen to dvd screen. Button is on front of unit to scroll through screens.
Kenwood kvt m700 help
Bu the sounds of it, you will only need to enter the mask code if the memory wire becomes disconnected, so I would assume that you have your power(red) and memory/constant 12v backword, or both hooked up to the power wire
3helpful
2answers
Kenwood KVT-617DVD sound issues
the wireing off the brain is connected wrong, ok look at the wires and now disconnect your remote wire from the amp remote now connect the second blue wire to the remote wire going to the amp, now your sound should be right
Kenwood kvt m700
The unit is clipping which means it's too loud, lower the volume and should be fine.
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
