Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
Dishwasher will not drain (water just trickes out) fill is good
Dishwasher will fill with good water pressure but will not drain at full capacity (water just trickles out on drain cycle)
Posted by zip406 on
  • zip406 Mar 26, 2009
    I check the drain valve it is functioning but I suspect that it is not obtain a good seal. It has a black O-ring around it. when I operate it by hand It does not look like its closing all the way
    The solinoid looks like it activating but the flapper does not look like it's closing all the way
Cleverer2
  • 298 Answers
Drain valve not opening or pump impeller loose on shaft - is it washing ok?
My guess would be drain valve not opening. It is a 110v solenoid and they get stuck or burn up. New solenoid costs ~$20.00
Posted on Mar 26, 2009
Aeg slimline dishwasher 64800. AL5 alarm, but fills up
This control procedure is in operation only during the cold wash and heating phases.
  • Once the pressure switch has closed in the "full" position, it must remain "full" until the subsequent drain phase; if the pressure switch signals "empty", the fill solenoid is activated for a period equivalent to the period of aperture of the pressure switch.
  • The maximum aperture time for the pressure switch (T) during the entire phase is 60 seconds; if this period is exceeded, an alarm condition is generated.
Alarm: AL5
Possible causes:
  1. Dishes upside down
  2. Central filter clogged
  3. Siphon effect created in drain hose
  4. Leakage in sump - pressure switch tube.
Dado
Mar 02, 2014 | AEG 18 in. Favorit 64800 Free-standing...
When turning on dishwasher it just fills the base with water, tried manually draining and pressing reset buttons to no avail
Most dishwashers kick on a valve to fill with water.
There's a float in there somewhere that triggers the shut off to the filling water.
Once water reaches this cut off level the pump should be throwing water thru the wash arms.
If base isn't filling to capacity...Id look to the drain valve.
If it fills to capacity and stops...the pump may be out or something is obstructing it.
Hope this helps...
Jul 30, 2011 | Neff 24 in. S5453X1 Built-in Dishwasher
Our dishwasher is retaining water in the base and not cleaning our dishes fully what is the problem?
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Hope this helps...
Daniel
Aug 15, 2010 | Frigidaire Gallery FGBD2451KB Full Console...
Fills arbitrarily not holding any water after a full cycle. All seems well and on any given day it will have filled without warning and floods floor
Check your drain hose to where it connects under the sink. If it is connected to the garbage disposer, and not looped upwards before it runs back to the dishwasher, it may just be drain water from the sink running back to the dishwasher. Even if it hooks up to a "t" spout under the sink, and the drains run a little slow, water can still run back to the dishwasher. The ideal set up is to have it connect to the drainage, run up behind the bowls of the sink, and then back to the dishwasher.
If this is not the answer, then you may have a defective fill valve that is allowing water to seep into the machine (very unusual in dishwashers). Also note that water valves require 23 psi of pressure to seat closed and if the incoming pressure is less than that, even a new valve may have the same issue.
Good luck and let me know how you make out, and if you have any other questions.
Bob
Jun 28, 2010 | GE 24 in. GSD4030Z Built-in Dishwasher
Not cleaning after full cycle
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 23, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishes in top rack don't clean
Hi
Thanks
Rylee
Dec 05, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Glasses are foggy and not clean- I tried using lime away with no good results. I have changed from powder to liquid soaps - with no results. I think the drain might need cleaning out, or ???
Hi
Thanks
Rylee
Nov 22, 2009 | Maytag MDB9600A Jetclean II Built-in...
My dishes weren't coming out clean so i took the guard off and cleaned it out but in the little cup under the holder there is always water in there but nothing is blocking it ( like food) is that cup...
Hi
Thanks
Rylee
Oct 12, 2009 | Dishwashers
Wont fill with water
Clean the floats inside the wash tank. If they get fouled, they will "trick" the machine into thinking it already has water in it
Jul 13, 2008 | Hobart 29 in. AM15-1 Free-Standing...
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
282 people viewed this question
Top GE Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Bill Johnson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
