The following lights are blinking and will not clear: Heavy Duty, Normal, Quick Clean-up, Rinse Only, Heat Dry and Cancel. I have tried the following key combinations to fix it, but they don't work: 1)High Temp (HT), Heat Dry (HD), HD, HT, HD, HD, start, start... and 2) HT, HD, HT, HD, start, start.... 3) HD, Normal, HD, Normal
Neither one of these solutions worked. I got solution #3 from the literature attached to the bottom, front panel. Do you have any other suggestions.
The normal light china light and cancel are all blinking. Tried (HD)(Normal)(HD)(Normal) and nothing.The normal light china light and cancel are all blinking. Tried (HD)(Normal)(HD)(Normal) and nothing.
The heavy duty light and the normal light are blinking and wont stop. The dishwasher won't run and won't cancel either.The heavy duty light and the normal light are blinking and wont stop. The dishwasher won't run and won't cancel either.
Today I have the following lights blinking (normal, Light/China and the Cancel) these all blink at the same time. I can't recall what the previous ones were but, currently these are simultaneously blinking . Any suggestions are greatly appreciated. I have taken no other steps beyond flipping the switch to the electric panel.Today I have the following lights blinking (normal, Light/China and the Cancel) these all blink at the same time. I can't recall what the previous ones were but, currently these are simultaneously blinking . Any suggestions are greatly appreciated. I have taken no other steps beyond flipping the switch to the electric panel.
heavy duty flashes, when cancel pushed heavy duty and normal flash,if restart pushed heavy duty, normal and cancel flash, if unplugged. will go off and only cancel blinks slow then is on steady. do anything goes back to heavy duty flashing. key presses heated dry-normal-heated dry-normal does nothing. The demo mode key presses: high temp-heated dry -heated dry-high temp-heated dry-heated dry also do nothing. The washer was bought new and sat for almost a year while we remodeled kitchen. Installed ran twice ok then would not go thru a complete wash cycle.heavy duty flashes, when cancel pushed heavy duty and normal flash,if restart pushed heavy duty, normal and cancel flash, if unplugged. will
AnonymousApr 12, 2009
mine is doing the same thingmine is doing the same thing
You can't post conmments that contain an email address.
An expert that got 10 achievements.
An expert that got 5 achievements.
An expert whose answer got voted for 100 times.
Master
Re: Lights blinking and won't clear
The solution #3 should work.. you may want to try again....
first turn off the Breaker to cut power then wait a few minutes then turn back on, then within 6 seconds try (Heated dry)(normal)(heated dry)(normal).. all lights should light up then you know that you are in the service cycle, and the unit should go into a self test and clear the fault. The test take about 30 minutes. let me know if you can get into it...
Press High Temp Scrub and Dry Heat option buttons in quick succession one after the other for about 6 sec until all the lights come on. Then press Cancel button. This should reset the dishwasher. Press equivalent buttons on the panel if the actual ones above are not there. Make sure the dishwasher detergent dispenser lid is shut and the dishwasher door is shut before you start the above reset sequence.
Have Whirlpool GU1500XTLT1 with exact same symptoms, even tried power off but the lights resumed blinking when powered back up. Used solution from "kent168" of 17 Nov 2010 for similar GU1500XTLS1 with a different problem, and IT WORKED: "Reset the machine: press control buttons in this sequence: sani rinse, air dry, sani rinse, air dry, clear."
Open the door.
Within 3 seconds press the following sequence --Try pressing normal wash,
heated dry, normal wash, heated dry, normal wash, heated dry three times within
6 seconds and then press cancel to reset the dishwasher. If that doesn't help
then try pressing Saini
Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air
Dry, Saini
Rinse, Air Dry, Saini
Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door
and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally.
If the light is still blinking try and reset the power to the dishwasher and
try again. If still the light is blinking then check for the connections on the
keypad, it may be due to moisture or shorted connections on keypad.
Hope this
helps... Please post back if you need more information.
Hi Open the door.
Dry, Saini
and press Cancel.
keypad, it may be due to moisture or shorted connections on keypad. Hope this
helps... Please post back if you need more information. Daniel
Open the door.
Dry, Saini
and press Cancel.
Hope this
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry,Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel. Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry,"
"Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore
dishwasher to run a short diagnostic test
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its
diagnostic test. This should reset your dishwasher control panel and
stop the "Clean" light from blinking repeatedly.
Good luck.
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Joe, see if you can reset the board by pressing heated dry-normal-heated dry-normal..(new board). Old board is high temp wash-air dry-high temp wash-air dry. See if it goes back to normal. If not you probably have a stuck or shorted keypad on the overlay..not the board. Catriver...post back
