Dear,
some times i get an message "Please insert SIM" while my SIM is fitted OK. and i have forgetten my Key guard code. so Please ask how to crack the Key guard code.
mines is 1110, and i forgot my keyguard code, now "key guard" settings is setted "off", am thinkin to "on" that thing cuz i forgot the code..... can i get a solution
Dear, some times i get an message "Please insert SIM" while my SIM is fitted OK. and i have forgetten my Key guard code. so Please ask how to crack the Key guard code. mines is 1110, and i forgot my keyguard code, now "key guard" settings is setted "off", am thinkin to "on" that thing cuz i forgot the code..... can i get a solutionDear, some times i get an message "Please insert SIM" while my SIM is fitted OK. and i have forgetten my Key guard code. so Please ask how to crack the Key guard code. mines is 1110, and i forgot my keyguard code, now "key guard" settings is setted "off", am thinkin to "on" that thing cuz i forgot the code..... can i get a solution
You can't post conmments that contain an email address.
Yes,
Sometimes it happens,when we push the sim card too hard into the slot.
So,put the sim card firmly into the slot to start the mobile without that text message.
To get the code to you,I need the IMEI number.To get it type *#06#.
"Rate high if you are satisfied with the problem"
Thanks
General Information about your Nokia 1680 unlock code
When you receive your email with your unique Nokia 1680 unlocking codes, you may see there's actually more than one code.
Depending on your model you may receive two codes for newer phones or seven codes for older Nokia models
(Please see below for some examples)
If you receive a code without the #pw+ at the beginning or EG +1# at the end, then you need to add this to the code before you enter it.
For example, if you receive 418636523456123, then the code is actually #pw+418636523456123+1# (Should normally be +1# on the end).
PLEASE NOTE
WHEN ENTERING A CODE, be very carefull, Nokia models only allow 3 attempts to enter a code, after this they will lock themselves.
When you enter a code and it returns an error code, STOP and contact us, making a note of the error exact message. If you continue it will affect your chances of a refund.
However it is worth trying to use your new SIM as some phones can falsly report a 'Code Error'
How to enter your Nokia unlocking code
Use the * (Star) Key to get the p w and + characters.
Press * key 3 times for p
Press * key 4 times for w
Press * key 2 times for +
Please note: You only have 3 attempts to enter this unlocking code.
To start with, when you turn your phone on without a SIM card you should see the message 'RESTRICTED'. If you don't see this message, turn the phone off and insert a non-accepted SIM card (ie not locked to) and carry on as normal.
First and foremost, you will need to purchase an unlock code.
Warning : Do not enter any wrong unlock codes on your Nokia 1280 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 1280 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 1280 without any sim card. 2 - Don't bother as to what is displayed on your Nokia 1280. 3 - Compose #pw+CODE+1#. 4 - The Nokia 1280 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 1280 mobile phones locked to the network Fido or Rogers in Canada follow these instructions : 1 - Switch on your Nokia 1280 without any sim card. 2 - Don't bother as to what is displayed on your Nokia 1280. 3 - Compose #pw+CODE+7#. 4 - The Nokia 1280 would then display the message "SIM Restriction Off" and will be unlocked!
The letter p appears if you press the button star(*) three times quickly The letter w appears if you press the button star(*) four times quickly The symbol + appears if you press the button star(*) two times quickly The CODE you need to enter is the unique unlock code for your Nokia 1280
the phone is ok, but the SIM can have some services activated, per example: Call Barring; or Call Diverting... in order to deactivate these functions, you'll have to type a deactivation code for each one: to deactivate the Call Barring you'll have to type this specific number: #33# and press the call key, when asked for a password, please enter 0000 and press the confirmation key. To deactivate the Call Diverting, please call this number: ##002# and then the phone will display a message like " Divert Cancelled " that is the confirmation that the Call Divert is deactivated, good luck. :)
your mainboard is having a problem reading your simcard.....you will need to take the phone to a mobile service center and have them either replaced or reflash the phone to correct the issue.....hopefully it is still under warranty and the fault was not cause by you the customer.
its either a loose sim tray or a problem with the Sim IC ...... use some packing over the sim card and see whether it works properly other wise you will have to get the sim IC changed
