I can light one burner to produce low flame only. Propane flow does not allow for both burners to produce flame at the same time. After one burner is lit when I attempt to light the second it will kill the...
Mike, your gas regulator is locked up. To solve the problem, do the following.
1. Turn the tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow) until the valve is fully open.
4. Light on burner and turn it to HIGH. Does the flame height look correct? If so, light the other
burner the exact same way. Do both flame heights look correct? If so, you solved the problem.
In the future, always remember to turn the tank valve ON very, very slowly.
If the above didn't solve the problem. You will need to replace the grill's Hose/Regulator Assembly. You can pick one up from any hardware store or home center that sells gas grills & accessories for about $30.00. Take you old one with you for comparison purposes.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!!
