Question about Citizen Eco-Drive BL006056H Wrist Watch
HOW DO I SET THE TIME ON MY ECO-DRIVE, IT LOST POWER.
MY WATCH WENT DEAD FOR TWO DAYS, THE TIME IS OFF, HOW DO I SET THE TIME?
Posted by ethbones1031 on
Arturs Kalnins
  • 2,338 Answers
Follow this link:
http://www.citizenwatch.com/COA/English/settings.asp
If this do not work, you have to change the capacitor.
Rate me, please.
Posted on Mar 26, 2009
Wath stopped
Eco-Drive powered watches can be finicky. They need a LOT of sun to initially charge the power cell, and then some strong light each day to maintain them charged. Put the watch in the window for a few days to see if it comes to life, if it does not the power cell may need replacement. Some of the earlier Eco-Drives used a capacitor that does not like to be run down from not being exposed to enough light, and will fail sooner than the newer power cells.
Jun 16, 2010 | Citizen Eco Drive Perpetual Calendar...
I own 3 Citizen ECO watches that have lost their charge.
Hiya Papahay,
are the crowns out at time set mode. This mode activates a 'hack device' ( a small spring in the watch) which will cut power to the circuit.
With the crown out and under light (even a desklamp directly with in a few mms above them) should do the trick.
These capacitors do need replacing, I suggest give the above a go for a least 24 hrs straight and go from there. When there are fully charge all you need to do is pull the crown out to time set mode and leave under light
Jul 11, 2009 | Citizen Eco-Drive Silhouette EW869452D...
Citizen Eco Drive
The Citizen Eco Drive watches use special recharchable batteries.
I started collecting a couple of watches and I noticed sometimes a jeweler replaces them with an ordinary battery. The watch will work and at the same time it will try to recharge this one until it explodes! In newer models they made it harder to use the non-rechargable ones by adding a special connector or clip to the rechargable battery types.
Okay,you stored your watch in a drawer as many people do? It may have lost the charge over time. First thing to try is to leave it on the window sill so the dial is in the sun. It will start ticking, but please leave it out there for 3 days to a week. The seconds hand will tick irregularly in steps of one and two seconds, to show you it wants you to readjust the time, as it knows it has lost time. Adjust the time and it should run smoothly.
The seconds hand should run in single second steps, if it takes steps regularly, but every 3 seconds or so, it tries to tell you that its power level is going down. It will be able to continue for one or two days, but you should get it into the sun more often.
Charging the battery under a lamp is possible, however this heats up the watch and this may reduce battery life.
If you need to know more about the Eco Drive, look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
Those are great watches as long as you remember it needs light to charge. Be sure to ask the watch repair man if he knows the eco drive uses special battery, if not sure, find another watch repair man before he kills your watch ;)
Jun 13, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Citizen Eco Drive second hand stoped working
Okay, if you say your battery goes bad, or watch does not run okay? It may have lost the charge over time. First thing to try is to leave it on the window sill so the dial is in the sun. It will start ticking, but please leave it out there for 3 days to a week. The seconds hand will tick irregularly in steps of one and two seconds, to show you it wants you to readjust the time, as it knows it has lost time. Adjust the time and it should run smoothly.
Charging the battery under a lamp is possible, however this heats up the watch and this may reduce battery life. As long as the watch keeps running I believe it should keep good time. It is quartz anyway. If this is not the case, and a good sunbath does not help, the mechanism could be running heavy, possibly due to overheating the watch; no help there...
May 31, 2009 | Citizen Eco-Drive BL5184-56L Wrist Watch
Okay, if you say your battery goes bad, did you store your watch in a drawer as many people do? It may have lost the charge over time. First thing to try is to leave it on the window sill so the dial is in the sun. It will start ticking, but please leave it out there for 3 days to a week. The seconds hand will tick irregularly in steps of one and two seconds, to show you it wants you to readjust the time, as it knows it has lost time. Adjust the time and it should run smoothly.
Mar 05, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
What is the proper battery placement or orientation for eco-drive
I started collecting a couple of watches and I noticed sometimes a jeweler replaces them with an ordinary battery. The watch will work and at the same time it will try to recharge this one until it explodes! In newer models they made it harder to use the non-rechargable ones by adding a special connector or clip to the rechargable battery types. If you look into the place where the battery goes, you will see a shiny spot where the metal clip needs to touch. If not sure, find the link to tech docs below.
Jan 05, 2009 | Citizen Eco-Drive Silhouette EW869452D...
Restarting my Citizen Promaster Eco Divers 200 Watch
Since it's eco-drive you can just wear it for a few hours and it should self-wind. The problem is that when it sits still for more than a few days it winds down. It gets its power from the natural movement of your wrist as you walk around.
Once it starts ticking again you'll just have to set the time correctly.
Dec 18, 2007 | Citizen Eco-Drive BL006056H Wrist Watch
Citizen Eco-Drive BL006056H Wrist Watch Logo
195 people viewed this question
Top Citizen Watches Experts
Janelle Schoonover
Janelle Schoonover
Lisa Christine
Bruce Robin
Are you a Citizen Watch Expert? Answer questions, earn points and help others
