SOURCE: pip is stuck and i don't even have a pip button on my remote!
The problem was solved by using the TWC cable remote control and selecting "TV" on the top and the press the big blue "Select" button. DO not forget to put the remote back into "CBL" mode. Apparently this is a hidden feature, which works even on TVs, which officially do not support PIP. I works only with the one tuner, video 2 and video 3 but not video 1.
SOURCE: PIP for Sony KV-27XBR45 television trouble shooting
If you have the original remote for this TV on the pip menu (left side slider on remote all the way up) there is a pip off button. If you unplug the unit long enough it should go back to normal. If you go into demo mode and then exit mode you will again be out of the pip. With out the original remote you cannot easily turn pip off.
SOURCE: PIP on an older SONY with DISH
If you are using the satellite remote then you need to contact the dish company and ask them how to program the remote. Good Luck
SOURCE: PIP won't turn off
I pressed "Demo" on the front of my TV and it worked, I have an old Sony KP-53XBR35 VIDEOSCOPE XBR - no original remote and the Universal remote has PIP button but would not shut it off.
Finally it's off!!!!
SOURCE: Don't have original remote for Sony tv, and can
Here a website to get the original remotes.1-800-Remotes Factory original.To buy exact remotes or very close to the original.No other way,tv control on the front of the tv don't have functions to work for PIP.
