Remains in standby condition itermidently
SOURCE: TV not tuning
Resolder the Vertical IC, it might help, or reflux it with a new lead solder. We experienced that. Somehow the vertical IC have some connection on AFC tuning.
Hope it helps.
SOURCE: Onida TV service code needed
press disp+vsm together here it opens service menu at last of that menu there is restore option press 1 to INT . press 1 and your tv will restore.
SOURCE: Sony KV25X5D CRT TV. When turned
Service manual: http://raoul.foucault.free.fr/docs/SONY%20KV-25X5.pdf
This ia an old CRT TV, THERE IS NO POWER SUPPLY BOARD BY ITSELF that you can buy! I sure like to see this 'POWER SUPPLY BOARD' from TVPARTSANDMANUALS.COM!
The main board has power supply, controller, Flyback xformer, etc.
You need to do in-depth troubleshooting, check the H.O.T, Flyback xformer, caps, etc.
SOURCE: my onida 21" black color
Possible there is a fault in soldering. Poor joints in the CRT base circuit of the CRT tube will result in poor connection after some use due to the fact the heating and cooling will detach off the leads. So use a good soldering iron to touch up all the points in your main board and the CRT board and it must work provided your tube is not faulty.
