I NEED A TRIPLER AND FLYBACK TRANSFOMER FOR MY TV.tHE TRIPLER MELTED!!!I DONT KNOW THE NUMBERS SO THAT I CAN ORDER FOR NEW ONES..PLEASE HELP.. THANK YOU.
SOURCE: Flyback? What else could it be?
Flyback is just one of many problems that may cause the rca itc22 chasis to shutdown. the fact that the green light flashes idicates that your processor is recieving power and that the processor is seeing a problem. DId you chech the horizontal output transitor. when u replace flybacks thats the first thing u check. there is a number of items that can shut it down. Technicians have special tools that can read the processor and find the errors that shut it down. the main board can cause problems also it the data becomes corrupt.
SOURCE: RCA D52W19BYX1 ITC222 I KNOW ITS THE FLYBACK TRANSFORMER BUT I NEED HELP
ASTI flybacks and RCA TV's don't mix. We have seen nothing but problems with them. OEM is the way to go if possible.
SOURCE: Flyback Transformer
you can remove them from the splitter and the focus block. the same leads should come with the new FBT.
SOURCE: Samsung HCP4363WX/XAA
Was wondering if you got set fixed yet? STK-392-180s are the ics I use when repairing convergence.Replace both chips.
SOURCE: flyback 259296
When you remove the rear panel look to the left side of the chassis and you will see the Flyback with the two wires coming out of the top one is a large thick red wire the other is a small wire. You can get a new replacement at the following link under 50.00 which includes free shipping and free support to help you install it by on line instant message with a repair tech.
http://servicemanuals.vstore.ca/
