Microsoft wiondows xp professional version 2002 servicepack 3 software needed for model no M1005 LASERJET SCANNER PRINTER
But it's scanning to SMB
And it's Konica Minolta bizhub c300
SOURCE: Toner fly in Bizhub 500
The problem may be comming from the drum unit, there is a small over sray tray right under the developer mag roller. It is mostly filled up with waste toner or dropped toner from the mag roller. You have to take out the drum unit and then the opc drum and vaccum out the tray and that should take care of the problem for now... The problem will come back..... Have you ever had the developer and or the drum & blade replaced. Minolta are a duel component copier. When the developer is worn out it will start to trow toner and fill up the small tray under the dev. mag roller..... Good Luck
SOURCE: ADF Paper Feed on Ricoh Aficio 1013
1-clean rubber belts with lint free clothes immersed in pure alkohl
2-remove adf covers and confirm that nothing broken inside(gears-belts)3-every clutch and selonid are in good condition.
4-solonid lever engaged firmly to gear slevee 5-apply light grease to gears and slevee6-confirm that nothing object the actuation of adf microswitches no dust and dirt in optical switches.
SOURCE: konica minolta bizhub 501
The problem is that the default setting ing the copier has been set to all ways do two sided. Ckeck your user settings just go through all the screen and look for orginal doc. setting, it should be set for simplex or one sided. If it is not there you may have to call your service rep. and have them change the setting in service mode. Some of the older and newer copiers have a setting in service mode. It is most like in your user settings. Someone was Panic Botton Pushing & will not fess up....Good Luck
SOURCE: adf misfeed ar-m237
Try cleaning the pick rollers with alcohol or clean cloth dampened with water.
