Replaced gas safety valve, burner flame now too hot
Oven would not ignite on GE XL44, Model JGBS23GEV4AD. Replaced igniter, same problem. Replaced gas safety valve, WB19K13, oven burner now ignites but flame is way too hot, engulfs flame spreader and goes up into oven. My oven is LP. Is it possible that the replacement valve is for natural gas and I need to utilize the outlet orifice from my old valve?
thanks. Apparently the new safety valve ships configured for natural gas. Tightened the orifice all the way down, problem solved.
AnonymousMar 13, 2014
Having replaced the Flame safety device some fifteen months ago it is now failing again. Should the new one have failed so soon. Also the igniter continues to click after ignition.Having replaced the Flame safety device some fifteen months ago it is now failing again. Should the new one have failed so soon. Also the igniter continues to click after ignition.
You can't post conmments that contain an email address.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
GAS OVENS
1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
The oven uses a silicone carbide ignitor which requires 3.6 amps or better to open the gas safety valve. If you don't see any glow from it then it is either blown or the gas valve has gone bad. If it is glowing but not real bright it probably is weak. How it works: Silicone Carbide Ignition XL44 gas stove manual
Most likely, you're oven igniter is not getting hot enough to open the gas valve to ignite the burner. It glows like normal, but does not reach the temperature required to open the gas valve. Replace the igniter. Before you replace that, make sure that the small shutoff lever on the appliance regulator was not accidentally closed, which would turn off the gas to the oven, while still allowing gas to the stovetop. The silver lever should be sticking straight out or up. Douglas
Hello there: It won't bake or even heat up correctly or If your oven won't bake, check these:Bake igniterOther causesBake igniterUsually
when an oven won't bake, it's because the bake igniter is weak or
burned out. The igniter is a small, round or rectangular device, that's
about 1 inch by 4 to 8 inches. It's near the burner itself. The
burner is the tube-type device the gas flows through before it's
ignited. It has many small holes on the sides to let the gas, when
ignited, form a long, low flame. If the igniter is weak, if it glows red
but doesn't get hot enough, or if it's burned out, the gas doesn't flow
to the burner and the burner won't ignite. If this is the problem, you
may need to replace either the igniter or the gas safety valve. Usually
the igniter is to blame.Other causesOther reasons that your oven may not bake are:The clock settings are incorrect (if you have timed baking or a self-cleaning oven). The thermostat is defective. The safety valve that prevents accidental gas flow is defective. The selector switch is defective.
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
Your problem is with the oven igniter. You have the stove MODEL# so you should have no problem finding the part you need.Shop around to get your best price. Good Luck Friend.
hi thanks for the question just because the igniter lights up doesn't mean its good, the gas will not light, if igniterisn,t hot enough. and a very common problem is that the igniter does come on, but not hot enough to ignite the gas . replace the igniter thanks the appliance doc
