Question about Denon AVR-1706 Receiver
1706 Red ring of death
I have a AVR 1706 and it will start to power up ! it will flash through the systems ! and when that is done and it should start to play music ! thered ring of death hits ! Aand when you reset it I hear a clicking and it will start all over again ! It had worked fine up until then ! Cant think of anthng that should of caused it !
  • Floyd23 Mar 27, 2009
    Same problem. The receiver trips at any time. AVR 1708
  • 75 Answers
Check all your speaker connections to make sure none have shorted out.
It appears the protector circuit is being activated upon startup. cut the power altogether to the unit before checking it.
Posted on Oct 02, 2009
  • Nancy Stukey
    Nancy Stukey Sep 21, 2013
    Thanks for the tip! My speaker wire was lose due to my dusting :o) pushed in in tighter and what do you know, my receiver turned on! So happy thank you for the information!
6ya staff
SOURCE:
How to hook up a denon avr -1706 receiver to a lg smart tv
When connecting your AVR-1706 to your LG TV, you will most likely be limited by the connections on your AVR-1706 as it does not have any HDMI capability.
In this case, depending on your LG TV, you would get the best video performance by using the component video connections from your TV to the Receiver. These are the one labeled Y, Pb, and Pr. These are special cables and you will need 2 sets if you want to run video out of your TV (perhaps you are using the internal tuner). Refer to page 6 of your AVR manual for the TV video inputs. Please note you will only use one type of input such as Component, S Video or Composite (descending order of performance). You must connect the Video Out from your AVR to the back of the TV's Video In as shown on page 6 as a minimum to get signals from devices other than the TV.
On page 12 of your AVR manual you can see the connections for TV outputs including the audio connections to the AVR. In the case of audio, you can either use Optical Digital (Toslink) out from the TV or coaxial (RCA) cables: Again in descending order of performance.
If you don't have the AVR-1706 manual handy, you can see it at the following link: http://a248.e.akamai.net/pix.crutchfield.com/Manuals/033/033AV1706B.PDF
Mar 02, 2015 | Denon Audio Players & Recorders
The red ring on the power button on my DENON AVR 1706 is flashing continuously, not sure what it means, after my niece turned it on, it turned off and started flashing. What's wrong with it, does anyone...
Hi, this flashing means that the device has a short circuit in any of speakers connections or it's overheated, in the first case check if the speakers wiring has no bare wires touching each other, in the second case check that the ventilation holes of device are not covered or blocked with something.
Oct 20, 2013 | Audio Players & Recorders
My denon avr-1706 is going into protection mode immediately after turning on. whats the problem?
You either have an overloaded output or a shorted powersupply. If you have verified that your connections are not the cause then the problem is internal and will require service from a trained technician. Switching power supplies are notorious for going bad. Two of the main components are the FETs used for switching and the PWM generator.
Feb 09, 2010 | Denon AVR-1706 Receiver
Denon avr-1706 receiver just shuts off
This sounds like the amps protector circuit has been activated due to thermal overload. switch it off for an hour or more to let it cool down, make sure your spkrs are connected properly, don't parallel. Try using a fan on the unit to get that heat away. Get a techie friend to give the insides a once over, and clear away any dust that has built up.
hope this is of some help,
Cheers Kimbo.
Sep 12, 2009 | Denon AVR-1706 Receiver
Denon AVR 1706 reciever
it a control switch and power supply that needs to be replaced they have blown.
get in contact with me so I can help you financially...I can buy your unit for parts.
It will cost more than the unit
[email protected]
Sep 27, 2008 | Denon AVR-1706 Receiver
Remote control for Denon AVR 1706
YES YOU CAN THERE MAYBE A FEW DIFFERENCE BUT YOU WILL BE FINE TO USE IT
Jan 10, 2007 | Denon AVR-1706 Receiver
No system setup menu on screen
its related to the control AVI switch inside on the right side with the contact and 7 Ri sisters.
about 200.00 something to repair.
I can help with some money do you have the reciever still???
Jan 04, 2007 | Denon AVR-1706 Receiver
Denon AVR-1706
if you still have this and it is not working i am looking for parts for this television, please let me know I would buy this from you, thanks
Oct 06, 2006 | RCA P61960 61" Rear Projection Television
No Power
I mwas gonna suggest that you need the speakers attached but you stated later that it did the same thing with the speakers attached. The unit switching off after it checks its self is NOT a normal thing. TAKE IT BACK BEFORE ITS TOO LATE!! GOOD lUCK
Jun 18, 2006 | Denon AVR-1706 Receiver
Denon AVR-1706 Receiver Logo
445 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
