It happens about once aday. water dripping from the freezer into fridgerator than down under crisper drawers
Hi
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Please do rate this solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
I think this is going to be very helpful but will have to let you know when fixed. Thanks in advance
The drain tube from the freezer to the drip pan freezes up causing water to drip into the refrigerator compartment. To unclog it I have to take the covers off and pour hot water into the tube until it thaws. This is happening about once a month. How can I stop this.
The tube from the freezer to the drip pan freezes up clogging the tube with ice and causing water to drip into the refrigerator compartment. To unclog the tube I have to take off all the covers and pour hot water into the tube until the ice melts. This has been happening about once a month. How can I prevent this?
There is water collecting in the dip below the storage drawer. I believe it may be coming from the freezer. Once it pools, it drips out the door onto the floor.
