Sansui HDLCD3250 32 in. LCD TV Logo
Anonymous Posted on Jul 01, 2013
My Sansui 32 inch LCD TV is not working
I have unplugged it and plugged it back in, nothing. The only indication that it is working at all is the red LED light in the bottom left corner of the TV. I have pulled it apart and inspected the fuses, there are no issues. None of them are bulging, all in working order.
Electro Med Services
Level 3:
  • Sansui Master 6,694 Answers
  • Posted on Jul 01, 2013
Sansui Master
Level 3:
Answers
6694
Questions
Helped
1870192
Points
21433
The main digital board stopped working. No SCL, SDA. Contact any service technician.
5 Related Answers
Anonymous
  • 396 Answers
  • Posted on Nov 05, 2009
SOURCE: I need the codes for a UEI technologies universal
www.manualsonline.com
Chi Chu
  • 8457 Answers
  • Posted on Mar 17, 2010
SOURCE: I have sound but no picture.
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board will get ur picture back.It a long board in shape.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.
Jerry Umali
  • 979 Answers
  • Posted on Apr 12, 2010
SOURCE: 110v lcd tv was plugged to 22ov outlet
Hello nik286, hi, check first the label at the back of the TV, look for a voltage input something like a 90V-240V, if you see this, its an autovolt system, this type of power supply input is standard nowadays. Assuming your asking what would be damage, this could be anything from the fuse, thermal resistor, rectifier diodes, and the regulator IC of the power supply board.
Bob Citizen
  • 520 Answers
  • Posted on Jul 17, 2010
SOURCE: Hooking up external speakers to Sansui HDLCDVD320
I'm sorry, but the Sansui HDLCDVD320 has no analog audio out jacks. If you have a cable or sat box, etc, you might be able to get audio from their outputs. I hope this helps you.
Anonymous
  • 8909 Answers
  • Posted on Nov 27, 2010
SOURCE: Picture quality is too bad in NEW sansui 32" LCD
As it is new, take it back for replacement. If you bought in online, have it replaced as it may have been damaged in transit.
Don't bother to try and repair it, it is not right.
Hope that helps.
Service code for 32inch sansui led tv sled hdr
Sansui model - LCD TV s 3281Yw-M I need sarvice mode code plz tell
Have a sansui tv model number dtv 2798 32 inch i
Check and replace damaged component/s at its main power regulator section circuit. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
1helpful
Won't turn on after unplugging sansui
Leave it plugged in for about an hour for it to warm up than it will work like normal. I have this problem every once and a while
Sansui lcd 32 inch will not turn on
the picture tube thing could have went out
My Sansui 32 Inch LCD screen shuts off, after a minute. The power remains on - the screen just switches off.
This may not work but i had a similar problem. My 32inch sansui LCD TV would switch off after about 10-20 minutes. I had to unplug it to get it going again. So i decided to open it as the warranty was long gone anyway. Very easy to open the back. I checked to see if anything was "swollen" as some sights suggested, but found nothing burnt , blown or swollen. Then i thought about heat? So i left in on without putting the metal backing plate back. It worked! when i put the plate back.....20 minutes and it shut down. So i just left the metal backing plate off! And no its not dangerous as the sansui has a protective plastic backing, that covers the metal one, that is better ventilated and protects the bits and pieces. Its been a week now and its fine.
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to [email protected]
Ilo 32 inch LCD television
leave the set unpluged for a while, about 1 hour and plug it back that should to do the job, if not call the repairman, you probably have another problem
good luck
[email protected]
1helpful
3answers
Tv doesnot power on
two options _bad backlight inverter or the main board ;eed to be change.
1helpful
Lcd TV
pixels or blocks like spilt images??
Top Sansui Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
