Question about Yamaha HTR-6130 Receiver
Yamaha HTR -6130 DTS?????
Ive got the my Sony Bluray hooked up to the yamaha HTR 6130 receiver using hdmi and an optical wire. In the Bluray setup, DTS in on. but for some reason The receiver only shows PCM or DOLBY, is DTS supposed to illuminate? if so, how can I get the receiver to play DTS formats??
Posted by dlbritton196 on
  • Anonymous Mar 31, 2014
    bluray movie loss of audio signal
Mike LaPres
  • 757 Answers
First, the sound source must also be in DTS. DTS is typically not the default audio selection on any DVDs that have that format...you'll have to select it.
Posted on May 08, 2009
Anonymous
Yeah!!! if u face any problem . contact with with at [email protected]([email protected])
Posted on Jun 20, 2009
I have hooked up my DTV box via HDMI to my Yamaha. I have hooked up my Xbox via HDMI to my Yamaha. I have Hooked up my Yamaha via HDMI to my Toshiba flat screen. I can get video from all but I am not...
It could have to do with the settings on each input device (xbox & DVR) -check their audio settings. I have a better solution for your problem though:
Since HDMI supports 7.1 ch of digital sound, I'd recommend using the optical inputs on your HTR-6130 that are made for 5.1 ch sound. I agree that you should be getting sound via HDMI, I was able to from my xbox to my 6130, but it gets cut down to 2 channel sound (good, but pales compared to true 5.1 ch sound). It believe it has to do with Dolby not being backward compatible going from 7.1 to 5.1. Anyhow, in order to get an optical-out on your xbox, you'll need connect with the a/v cables that came with the xbox, along with the HDMI cable. Depending on how old your xbox is, and which model (like an elite edition, etc), You may need to buy a special converter that will allow enough room for both an HDMI connection and the A/V connection. Trust me, I have an HTR-6130 with an xbox and a cable-provider issued box running through it. Optical is the way to go for this particular receiver since it only supports 5.1 ch sound. You can still use the HDMI ports on the receiver as a switch between your two devices, or you could choose to bypass it if you TV has more than one HDMI input port.
Nov 20, 2010 | Yamaha HTR-6130 Receiver
No sound on DVR HDMI port, but does work on other HDMI port
Not all HDMI ports support Audio or they do but only one way Audio out or Audio In. If you have an optical connection you can try that.
Apr 04, 2010 | Yamaha HTR-6130 Receiver
How to hook up a xbox 360 console to my yamaha 6130 receiver
You will need an additional HDMI cord...you can get them without getting ripped off by purchasing at bluejeanscable.com.
Connect your HDMI out from the xbox to the receiver. Connect the additional HDMI cable to the "out" HDMI connection on the receiver and connect the other end of it to your TV.
Apr 01, 2009 | Yamaha HTR-6130 Receiver
Yamaha HRT 6130 cable questions
You would need 1 component and 1 HDMI cable.
Mar 15, 2009 | Yamaha HTR-6130 Receiver
No sound
I had the same problem on 3/21/09...I found it was the PS3 settings. I had to go into the visual settings (not sound) and change the linear sound to optic digital...but I also had to purchase a digital optical cable...plug everything into your tv instead of the receiver and then hook up the digital optical cable from your tv to the receiver. A it will work and b it is a better sound quality than that of the HDMI cable.
Mar 14, 2009 | Yamaha HTR-6130 Receiver
Hooking up multiple components to HTR 6030
Once you have installed all the cables to the system, you will need to go in to the Yamaha's system settings (see owner's manual) and assign the audio inputs accordingly. The DVD input will need to be set to the optical input # you have selected. Optical and digital coax are not preset in most cases. Once you get to the input selection assign the digital # for DVD and then exit out. You should begin to hear the audio immediately. If not you missed a step. I do this for a living and every unit has its own routine you need to learn.  Enjoy the system Rob
Feb 27, 2009 | Yamaha HTR-6130 Receiver
I have a Yamaha HDR 6030 system and have hooked it up to a bluray player on a HD 1080p tv. Which of the sound setting (prologic, dts, dolby etc) is the best one to use for watching movies?
Each of the modes are true surround sound. Some are newer and may have advantages/disadvantages depending on personal preference. Prologic is the oldest of the listed, followed by dolby and dts. You can perform a google search to see the differences in dolby and dts but they should both be equally good. I prefer dts.
Dec 23, 2008 | Yamaha HTR-6130 Receiver
PS3 connection to Yamaha HTR-6130 Av Receiver
URNOTME is right. HDMI is great and all, but wish i would have spent a few more dollars on a unit that supports switching. htr-6130 does pass-through, so you have to use seperate audio connections. really there is no use running HDMI into the receiver and then into the receiver and THEN to the tv. just go straight to the tv, then run your audio either optical (best) or coaxial.
Nov 28, 2008 | Audio Players & Recorders
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Yamaha HTR-6130 Receiver Logo
661 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Will
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
