Question about Xerox Phaser 8550DT Thermal Printer
Blurry Printing Our Xerox Phaser 8400 is printing incredibly blurry. I have tried both troubleshooting options (eliminate light smears, eliminate print smears) several times and nothing is working! I have cleaned out the trays of ink waste and it is still smudging the print. How do I fix it?
Posted by callen697 on
Anonymous
    Scholar:
  • 141 Answers
Quite possibly, your Wave Amp board has failed. If so, it is more cost effective to purchase a new printer than to repair yours unless you can find used parts.
Currently, Xerox is offering a trade-up rebate on new solid ink printers.
Posted on Aug 04, 2009
My Xerox 8400 is printing the wrong colors. Where it's red, it's printing a brown shade and where it should be grey, it's printing green. My logo is grey and red and it's printing all grey, but not the...
Try printing a light stripes test page (Troubleshooting, print quality problems, troubleshooting print quality page).
If you do not appear to have many missing jets but the colours are all just wrong it may be that the ink has gone stale. Run a couple of head cleans and you should see the colours start to improve. If it is getting better, all you can do is keep running head cleans until you have replenished all the ink in the printhead well.
This problem is common in situations where a lot of black and white printing is done, with very little colour.
Alternatively, it could be that your wiper/cleaning blade is not cleaning the head properly and is smearing the different coloured inks across the head, or possibly that your printhead is leaking colours but I think the first solution should solve your problem.
Hope this helps.
Dec 09, 2010 | Xerox Phaser 8400 Laser Printer
Very blurry Print
please change your printer cartridge and buy a new one
Aug 13, 2009 | Xerox Phaser 8400 Laser Printer
Clean an 8400
Replace the maintenace kit and then in the menus run eliminate light stripes and eliminate smears.
There really isnt much else to do.
What you do when you run the light stripes and smears modes the machine removes all the ink from the print head, turns on a compressor and blows out the jets on the print head.
There really isn't a "cleaning " procedure as with a laser printer. If the maintenance kit is good, it pretty much maintanes itself.
Jan 06, 2009 | Xerox Phaser 8400 Laser Printer
Phaser 8400 Printing Blurry
The Drum Encoder is behind the fan assembly.
When you take the encoder cover off be extremely careful.
Use a cotton swab on the disc only with just a light amount of alcohol on the encoder disc.
Dec 17, 2008 | Xerox Phaser 8400 Laser Printer
Pinstripes in image after print (phaser 8560)
Appropriate cleaning procedures, as listed in the following tables, should be
performed when specific print-quality or paper transport problems occur.
All cleaning procedures are detailed in the printer’s Phaser 8400 Reference Guide or
the Phaser 8500/8550 User’s Guide.
Light Stripes or Missing Colors
Problem type Solution
Missing or light-colored
stripes on prints.
Select the automated procedure Eliminate Light Stripes from
the Control Panel.
Ink Smears, Oil Spots, or Random Ink Streaks
Ink smears on the front,
back, or edges of a page.
Select the automated procedure Remove Print Smears from
the Control Panel.
Check the maintenance kit for ink and paper-dust build-up on
the wiper blade.
Oil (drum fluid) on top edge
of print.
the Control Panel.
Hope this helps
pdouglasss
Nov 24, 2008 | Xerox Phaser 8560DN Laser Printer
Xerox 8400 light printing
No, If one lamp goes out they both will not function. They do not have anything to do with print quality.
You may have a bad maintenance kit. but more than likely you have a bad print head.
Run the cleaning , eliminate stripes and eliminate smears modes. But more than likely the print head is bad. I would say a bad print head is about a 95 percent chance of causing your problem.
The halogen lamps only heat the drum, and if one was bad the machine would fault out with a 15,004 code.
Oct 11, 2008 | Xerox Phaser 8400 Laser Printer
I have a phaser 8400 banding problem. Actually reverse banding. It is ligher ink vertically along left margin and an inch from right margin. Is this a drum problem? It notes I am low on ink and have only...
nope its not a drum problem, That drum never goes bad. You are having a problem with some blocked jets in the print head.
You can scroll through your menu to troubleshooting and there are cleaning modes to eliminate light stripes and to eliminate smears.
Run the eliminate light stripes maybe 2 or 3 times. If that doesn't work, then try the jet substitution mode.
That is better described at Xerox.com, click support, then enter phaser 8400 in the search box, click support again and then enter
"jet" in that search and follow the directions.
If those do not work then your print head is most likely bad. Thats more likely if you have used non xerox ink sticks.Being low on ink should only give you a message that its low.
Aug 25, 2008 | Xerox Phaser 8400 Laser Printer
Phaser 8560 blurr
There is an encoder on teh drum motor that picks up lubricant from the maintenance kit and causes those blurs. It eneeds cleaned or replaced
Jul 11, 2008 | Xerox Office Equipment & Supplies
Xerox Phaser 8400N Printing Stripes
When you go into the eliminate light stripes there is also a mode called Jet Substitution. You can sometimes bypass the bad jets.
If that does not work then the print head will most likely need to be replaced.
You can replace the printer for less than the cost of a print head normally..
Jul 08, 2008 | Xerox Phaser 8400 Laser Printer
Phaser 8400 is printing very blurry throughout documentst. The text is not legible. Seems like double-printing. is there a procedure to correct this problem? I've already made some adjustments. maybe...
It sounds like the drum encoder is bad and will need to be replaced. Is it still under warranty? Call Xerox. Or find someone who is trained to fix printers to repair it for you.
Good Luck.
Apr 06, 2008 | Office Equipment & Supplies
Xerox Phaser 8550DT Thermal Printer Logo
435 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
